Thread started 29 Jan 2013 (Tuesday) 00:44
Can a Feisol CT3144T handle a 100-400 with bracket & Flash?
jbrackjr
Joined Dec 2011
Jan 29, 2013 00:44 |  #1
Title says it all. Looking for a good tall travel tripod and it seems most recommendations are for the Feisol. However, I would like to be sure it can handle my largest lens prior to purchasing. Unfortunately, I live far from any locations that would stock this caliber of tripod, so there is no chance to go and try one out.
In searching I have found the Sirui M3204 which on paper exceeds the Feisol in every catagory, with the only negitive being the weight at 3.7 lbs/1.7Kg. and also about one inch longer retracted. The Sirui has 32mm legs vs 28mm for Feisol, so it is an apples and oranges comparison.
I am wondering if the Feisol will do the job, or get the bigger Sirui to be on the safe side. They both are very similar in price, so it doesn't factor in.
Oh, I do not plan on hiking with it. Just planes, trains and automobiles!
Jim
Nightdiver13
Unabashed nerd!
Jan 29, 2013 00:55 |  #2
Guessing you mean the 3441T? It should have no problem with that set-up, assuming you're using an equally robust head.
Neil
jbrackjr
Joined Dec 2011
Jan 29, 2013 08:11 |  #3
Yes, I seemed to have transposed the numbers. :oops:
With the 100-400 I use the Mongoose 2.3 gimbal head which was made for the smaller 400mm lens. It works amazingly well on my Benro (its 26 inches long and not good for travel).
Thanks for the feedback on the Feisol.
Jim
Jptenberg
Jan 29, 2013 18:46 |  #4
I have the 3441s and it is fine for my 100-400, but note that when you raise the center column, if it's breezy, you get some wobble. I attribute that to any small pod with the center column up though. It's not that the pod is unstable, but rather the size/weight of the lens combined withthe wind just torques the column to produce a rotational "vibration" at a certain frequency.
I have not had problems with the column down. I am using the Acratec GP-s head on this setup, and I am happy with the way it mates with these legs.
Upgrading from an Aluminum Benro to the CF Fiesol, the Feison is redicucously light. I would be worried about it blowing away at times if the camera was not weighing iit down. :)
5D3 | 7D | 17-40L | 24-105L | 70-200L IS II | 100-400L | 24LII | TS-E 24LII | 100L | 135L | 15-85 | Zeiss 50 1.4 | Tokina 11-16 | 580EXII | 430 EXII | Gitzo 3541LS | RRS Leveling base | Arca-Swiss Z1 | RRS Lever Clamp | Gitzo 2542T | Acratech GP-s | RRS TFA-01 with BH-25LR | B+W MRC CP Filters | Hoya ND Filters | Clik-Elite packs | Crumpler bags
761 views & 0 likes for this thread
Latest registered member is dm19dm
1671 guests, 313 members online
