I'm going to buy my first lighting gear and I think I'd like to use a BD as my first modifier.
Depending on my budget, I'll either buy a Kacey 22" BD
or a Mola Setti 28" BD
I'm interested primarily in Avenger stands.
I think the Avenger A2030D 9.8' Turtle Base C-Stand Grip Arm Kit would work well, but I'd like to verify with all of you first. BH LINK![]()
Avenger A2030D specs:
Minimum Height 4.4' (1.3 m)
Maximum Height 9.75' (3 m)
Closed Length: 4.4' (1.3 m)
Arm: 40" (1 m)
Footprint Diameter 3.1' (94cm)
Weight 13.7 lb (6.2kg)
Maximum Load: 22 lb (10kg)
Attachment Size Baby 5/8" male stud stand top
Junior 1-1/8" Receptor on base without stand
Accepts Wheels No
Air Cushioned No
Would the Avenger A2030D allow me to use either BD safely and securely like the c-stand / BD combo in this image?
The BD / strobe combo in the image are from Speedotron. I have absolutely no idea which c-stand that is. If someone can identify it, or recommend a c-stand, I'd be grateful.
