Thread started 29 Jan 2013 (Tuesday) 15:34
Im Trying To Create a CanvasTriptych in Photoshop
carshop
Jan 29, 2013 15:34 |  #1
I want To Create a Canvas Triptych in Photoshop.
I have searched here before asking, but to no avail.
Im fairly new in Photoshop want to be able to I can print the 3 panels seperatly, then wrap them.
Is there an easy way to do this in CS5?
Does anyone know of an action?
I have seen some tutorials on the web, but when it comes to printing, theres no description on printing the 3 panels individually.
Thank in advance as always.
Shawn
ShawnSmugmug (external link)/Flickr (external link)/LikeMyFacebook (external link)
Canon 70D Gripped|
Canon 70-200 2.8 IS|Canon 24-105|Canon 18-135
Canon 580 EX II|Sigma 18-50 2.8
Canon 55-250|Sigma 17-35 2.8| 2 Pocket Wizard II
kirkt
Jan 29, 2013 15:44 |  #2
Are you saying that you have a single image, let's say in landscape orientation, that you want to divide into three sections and then print and wrap each section individually so you can hang them in a triptych?
If that's the case, then you need to figure out how big you want the final piece to be and up-res if necessary to a pixel resolution suitable for canvas. You can probably do this by slicing your image first, then up-resing each section individually, but that will be a pain if you decide you want to change the slicing. It may be more burdensome (computationally, if your machine does not have a lot of RAM and you want a big final image) to up-res the entire image, then slice a copy and keep the full up-res'ed one as a master image.
As far as prepping for a wrap - find out from the printer how much wrap is required (1 or 2 inches, maybe?) around each edge of the image. You can simply extend the Photoshop canvas (Image > Canvas Size) and fill the extended area with pixels from the image near that edge - some folks mirror the edge pixels, some smear them, whatever.
If you need a plug-in to help and you will be doing this kind of thing frequently, OnOne makes a photoshop plug-in called Perfect Resize - I think the newest version of it may have a different name, but same concept. Attached is a screenshot - see how the wrap is automatically created and, in this case, reflects the edge pixels onto the wrap areas. Automagically!
I hope I'm not misinterpreting what you want to do - the best bet is to find a good printer who will work with you to achieve your intended output. Their process may have specific requirements that you will need to follow anyway, so best to get them involved early in the process so you don't waste a whole lot of time and effort undoing mistakes you could have avoided.
good luck!
kirk
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/01/5/LQ_635023.jpg
Image hosted by forum (635023) © kirkt [SHARE LINK]
Kirk
carshop
Jan 29, 2013 15:49 |  #3
Thanks kirkt
Yes, I want to do a single image into 3 sections.
I have extensive experience in canvas wrapping and printing with my Epson 11800.
Just wanted a shortcut, lol.
I have an action now that does it, but it puts a frame around it.
I dont want it framed.
Canon 70D Gripped|
kirkt
Jan 29, 2013 15:56 |  #4
In the time it took me to edit my post, you answered some of my questions. The plug in I mentioned above may be what you are looking for after you slice your image. It also does batch processing, so you could make your slices at their native size/res and then run the files in a batch through the resizing and gallery wrap settings.
You can use the Slice tool in PS to make your slices of the original image and then use Save for Web to save each slice automatically as a separate JPEG ready for up-res and wrap extension in batch Perfect Resize.
kirk
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/01/5/LQ_635029.jpg
Image hosted by forum (635029) © kirkt [SHARE LINK]
Kirk
carshop
Jan 29, 2013 16:01 |  #5
I'll look into that plugin.
Canon 70D Gripped|
carshop
Jan 29, 2013 16:57 |  #6
The plugin is ideal for mirror wrapping, but not what im really looking for.
Thanks for your effort, much appreciated.
Canon 70D Gripped|
kirkt
Jan 29, 2013 17:06 |  #7
What are you trying to do?
kirk
Kirk
carshop
Jan 29, 2013 17:36 |  #8
Ideally something with less work.
I was looking for an action, that would let me load the picture, run the action, than I can print the 3 panels seperatly.
Here is a free one, but it makes a frame, I dont want the frame.
MW Triptych Frame Photoshop Action
http://www.mwphotoshop​actions.com/free_downl​oads.html (external link)
Half way down the page
Canon 70D Gripped|
Lowner
"I'm the original idiot"
Jan 30, 2013 05:33 |  #9
From what has been said I would simply crop each seperate section, save it with a different name, then Edit>step back which will allow the second section to be cropped and just repeat a third time.
No need to overcomplicate life if my phylosophy. Just note where you crop each time so that it can be matched.
Richard
chrisa
Gallery: 184 photos
Jan 30, 2013 11:51 |  #10
I've used this free plugin in the past
http://lumens.se/tychp​anel/ (external link)
carshop
Jan 30, 2013 12:12 |  #11
Hi Chrisa
I have that plugin too, its great.
But it doesnt give you the option to split one picture into 3 frames.
Unless Im doing something wrong?
Canon 70D Gripped|
4,617 views & 0 likes for this thread, 4 members have posted to it.
1432 guests, 133 members online
