Thread started 09 Jan 2006 (Monday) 08:10
problom with my new Extender EF 1.4x II
xnuzha
1 post
Jan 09, 2006 08:10 |  #1
hi all
i have purchased new canon 100-400 with canon Extender EF 1.4x II
and i have the canon 350d / Digital Rebel XT
but the auto fucus does not work
can anybody help me please ???
Tapeman
Sliced Bread
Joined Jan 2004
Jan 09, 2006 08:29 |  #2
I believe that your autofocus requires a f5.6 or faster to work properly.
Your 5.6 lens & 1.4 converter combined is f8
Canon G1X II, 1D MKIV, 5DSR, 5DIV, 5D MKII, 16-35/2.8L II, 24-70/2.8L II, 70-200/2.8L IS II, IS, 100-400/4.5-5.6 L IS II, 500/4 L IS II, 24-105/4 IS, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, 2X MKIII,580EX II, 550EXs(2), ST-E2.
Gitzo 1228, 1275, 1558, Lensbaby 3G. Epson 3880, Bags that match my shoes.:)
Jon
Joined Jun 2004
Jan 09, 2006 08:31 |  #3
Right - the aperture of the 100-400 + 1.4x TC is f/6.3-f/8; only the 1D series will maintain AF at those apertures.
Jon
Cocker Spaniels
BTBeilke
Jan 09, 2006 08:33 |  #4
From the Canon website:
This tele extender can be used with fixed focal length lenses 135mm and longer (except the 135mm f/2.8 Softfocus lens), and the EF 70-200 f/2.8L, 70-200 f/2.8L IS, 70-200 f/4.0L, and 100-400 f/4.5-5.6L IS zoom lenses. Superb optically, it preserves the image quality of the lens it's mounted to and multiplies its focal length 1.4x. Effective aperture is reduced by one f-stop; autofocus is possible on any EOS camera when combined with a lens having an f/4 or faster maximum aperture. The new version II maintains the outstanding optics of the previous version, and adds enhanced weather-resistant construction, and improved anti-reflective surfaces in the barrel.
The 100-400 f/4.5-5.6 doesn't appear to meet the necessary criteria for maintaining autofocus capabilities.
Blane
BTBeilke
Jan 09, 2006 08:44 as a reply to  @ Jon's post |  #5
I've always been told that AF capabilities using the TCs are totally lens dependent and have nothing to do with the camera bodies. I use the 2x II on my 300D with the 70-200 2.8 IS (2 stop reduction, effective max. aperature of 5.6) without any problems. Does it the body really make a difference?
Blane
Jon
Joined Jun 2004
Jan 09, 2006 08:50 as a reply to  @ BTBeilke's post |  #6
The 3x0D and x0D/Dx0 series have an f/5.6 max AF aperture capability. This is documented in, for instance the 20D manual on p. 64; the 350D manual p. 70.
Jon
Cocker Spaniels
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jan 09, 2006 08:52 |  #7
Do take a look at the Teleconverter sticky FAQ thread in the lens forum.
CDS' HOT LINKS
BTBeilke
Jan 09, 2006 09:02 |  #8
Thanks guys. I learn something new everyday on this board! Does the 5D require f/5.6 also?
From the FAQ:
Requirements for Auto Focus
Canon makes SLRs with TWO distinct Aperture requirements for Autofocus. (AF)
A: The 1 series can AF with apertures as small as f/8
Models include; EOS 1D, 1Ds, 1DMkII, and film cameras EOS 1 and EOS 3
B: All other EOS bodies require f/5.6 to AF
Models include D30, D60, 10D, 300D, and 20D
Film bodies = all of them except for the 1 and 3
Blane
mojo_uk
Joined Jun 2005
Jan 09, 2006 09:04 as a reply to  @ BTBeilke's post |  #9
Afraid so, Canon saw fit to limit AF to 5.6 on all bodies bar the 1 series pro bodies to prevent inacurate AF. Your 70-200 2.8 works with the 2x convertor as it doesn't exceed 5.6. The 100-400 is already at 5.6 so even with the 1.4 extender it is prevented from AF by the limiter in the 300d's electronics. I have the 100-400 and 1.4 extender also and found a work round on this forum which involves covering 3 of the pins on the lens that send data to the camera. In effect covering those pins stops the lens sending the max aperture data and allows AF. In practice it isn't very effective as the AF is very slow and hunts like crazy making manual focus a quicker option. Which is probably the reason Canon limited it to 5.6 in the first place. Hope this clears it up for you.
Regards, Mark.
Canon 20D, Battery Grip, EF 100-400L IS, EF-S 18-55, EF 28-105, EF 50mm, 1.4 II Extender, 550 EX flash, 40 Gig Xs-Drive2 XL.
SWPhotoImaging
Joined Nov 2003
Jan 09, 2006 09:23 as a reply to  @ BTBeilke's post |  #10
[QUOTE=BTBeilke]Thanks guys. I learn something new everyday on this board! Does the 5D require f/5.6 also?
YES
SWPhoto-Imaging
tony1989tony
Jan 09, 2006 09:42 as a reply to  @ SWPhotoImaging's post |  #11
To test the min aperture any body will stop focussing at, stop it down in 1/3 increments press the dof preveiw button, 1/2 press shutter button and see if the distance scale moves.
D60/10d/20d all stop focussing at F5.6:o
D60, 10D, 5D, 1V, 3
17-40 F4L
28-135 F3.5 IS
24-70 F2.8L
24-105 F4L IS
50mm F1.0 L
50mm F1.4
85mm F1.8L
135mm Soft Focus
200mm F2.8L
70-200 F2.8L IS
300mm F4L IS
400mm F4L
180mm F3.5L Macro
Canon 580EX
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jan 09, 2006 09:50 as a reply to  @ BTBeilke's post |  #12
BTBeilke wrote:
Thanks guys. Does the 5D require f/5.6 also?
From the FAQ:
The key here is "all other EOS bodies,.
This includes the 5d and 350D.
CDS' HOT LINKS
BTBeilke
Jan 09, 2006 10:21 as a reply to  @ CyberDyneSystems's post |  #13
Thanks. That is what I assumed when I read it, but since it wasn't specifically listed, I just wasn't sure if the FAQ had been updated or not since the release of the 5D. With the 5D falling into the space between the 1D series and the 20D series, I thought perhaps this limitation had been upgraded on the 5D.
Blane
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jan 09, 2006 10:48 |  #14
Well your right of course. it had not been uodated :0 :lol:
I'm off to do that now ;)
CDS' HOT LINKS
1,550 views & 0 likes for this thread, 8 members have posted to it.
2471 guests, 99 members online
