I want to buy one for my 24-70II to explore into long shutter speed photography during the day.. you know, waterfalls and such.. which filter do you guys recommend? 82mm thread ofcourse.
Are lee big stoppers the best? whats the best bang for buck?
5W0L3 Senior Member 998 posts Likes: 14 Joined Mar 2012 More info | Jan 31, 2013 08:10 | #1 I want to buy one for my 24-70II to explore into long shutter speed photography during the day.. you know, waterfalls and such.. which filter do you guys recommend? 82mm thread ofcourse. Manav
Superdaantje Senior Member 557 posts Likes: 10 Joined Aug 2010 Location: Netherlands More info | Jan 31, 2013 08:19 | #2 I use the Lee big stopper on the 24-70 II (5D3) And works like a charm. Wagner.photography -
aegid Senior Member 506 posts Joined Apr 2011 More info | Jan 31, 2013 23:49 | #3 For 82mm it's the best. It's too bad they made the 24-70 II a 82mm because for 77mm the B+W screw-in is much cheaper and easier to deal with. 5d3,17-40,24-105,24 1.4,85 1.4,70-200 2.8 is ii
Superdaantje Senior Member 557 posts Likes: 10 Joined Aug 2010 Location: Netherlands More info | Jan 31, 2013 23:50 | #4 The filter size is no problem. I'm happy that the 24-70 II has 82mm. So I have to buy only the 82mm. Because I also use the 16-35 II Wagner.photography -
IndecentExposure Goldmember 3,402 posts Joined Jan 2007 Location: Austin, Texas More info | Feb 01, 2013 00:07 | #5 If you are in the market for Big Stoppers or other 4x4 10-stop filters, thread size means little. 77, 82, whatever, it still needs an adapter ring and that ring costs the same regardless. 4x4 and 4x6 filters have the advantage of being mounted cheaply onto any size filter thread. - James -
irishman Goldmember 4,098 posts Likes: 14 Joined Jul 2007 Location: Scottsdale, AZ More info | Feb 01, 2013 12:31 | #6 Indecent Exposure wrote in post #15558741 If you are in the market for Big Stoppers or other 4x4 10-stop filters, thread size means little. 77, 82, whatever, it still needs an adapter ring and that ring costs the same regardless. 4x4 and 4x6 filters have the advantage of being mounted cheaply onto any size filter thread. And with a 4x4 system you don't have to worry about screwing in a 10-stop filter and being blind without unscrewing. With a 4x4 you just snap off the holder, focus, compose, fiddle, and snap back on. Easy peasy lemon squeezy. To answer the OP's question, yes, the BIG Stopper is probably the best. Though, with Hitech's recent change to their formula the difference isn't as dramatic as it used to be. Bang for the buck, check out Hitech's 10-stop Prostop 4x4. Which also has the advantage of actually be found on shelves. Thanks for the info! 6D, G9, Sigma 50 1.4, Sigma 15mm Fisheye, Sigma 50 2.8 macro, Nikon 14-24G 2.8, Canon 16-35 2.8 II, Canon 24-105 f/4 IS, Canon 70-200 2.8 IS, tripod, lights, other stuff.
pdrober2 Goldmember 2,318 posts Joined Nov 2010 Location: Durham, NC More info | Feb 01, 2013 12:49 | #7 aegid wrote in post #15558708 For 82mm it's the best. It's too bad they made the 24-70 II a 82mm because for 77mm the B+W screw-in is much cheaper and easier to deal with. Thats what i have, its great. its also one of the reasons i dont want to go to 82mm thread size lenses. Fujifilm X-T1 | 23 | 27 | 56 | 90 | 55-200
RHChan84 Goldmember 2,320 posts Likes: 24 Joined Apr 2011 Location: Mass More info | Feb 01, 2013 12:58 | #8 I was going to pick up the HiTech and ever with the reviews of magenta casting, I was fine with it and a little PP can fix it. But UniquePhoto recieved some and ended up with the Lee instead. Canon (60D Gripped | 18-135mm f3.5-5.6 IS | 40mm f2.8 | 50mm f1.8 | 70-200 F4L IS| 430 EXII)
| Latest registered member is semonsters 1059 guests, 104 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
