Right i know this is a silly question but if setting up in aperture priority in low light is there a feature like on the 20D to set the sync speed of the camera to 1/200 rather than it being in sync with the cameras exposure.
Gadget-Guy Senior Member More info | Jan 09, 2006 12:04 | #1 Right i know this is a silly question but if setting up in aperture priority in low light is there a feature like on the 20D to set the sync speed of the camera to 1/200 rather than it being in sync with the cameras exposure. The equipment you'll leave at home will be the equipment you'll need the most!
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Jan 09, 2006 12:46 | #2 Nope, you're out of luck unless you switch to manual and set the shutter speed to 1/200 yourself since you know that's what you want. ...Leo
Cheers i thought that would be the answer.Will just have to experiment on the rare occasions i use flash. The equipment you'll leave at home will be the equipment you'll need the most!
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Jan 11, 2006 13:50 | #4 Gadget-Guy wrote: Right i know this is a silly question but if setting up in aperture priority in low light is there a feature like on the 20D to set the sync speed of the camera to 1/200 rather than it being in sync with the cameras exposure. Yes. CF 3-1 will default the shutter speed to 1/250 sec. when the flash is used in Av mode. If the flash isn't up to power, or you turn it off, shutter speed will revert to that needed for ambient light. Jon
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Jon wrote: Yes. CF 3-1 will default the shutter speed to 1/250 sec. when the flash is used in Av mode. If the flash isn't up to power, or you turn it off, shutter speed will revert to that needed for ambient light. Unfortunately, the 1Dm2(N) does not have C.Fn-03 implemented so it can't be set. ...Leo
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | PacAce wrote: Unfortunately, the 1Dm2(N) does not have C.Fn-03 implemented so it can't be set. Sorry, misread the post as "a feature, like, on the 20D" Jon
| Latest registered member is semonsters 909 guests, 123 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
