Thread started 01 Feb 2013 (Friday) 11:30
Gaffer tape grid
JakAHearts
Feb 01, 2013 11:30 |  #1
Anyone ever try making a softbox grid from gaffers tape?
I was thinking if you made a bunch of strips made from two strips of gaffer tape, stuck sticky side to sticky side. Then, Id cut halfway into each strip at even intervals and then make a grid pattern by sticking the slits into each other. Then tape across to seal all the edges, attach sticky velco strips and WAHLAH! Grid for about 15 bucks and a bit of time, any size you want.
Yes, no, maybe?
Shane
ksbal
Gallery: 374 photos
Best ofs: 9
Feb 01, 2013 12:30 |  #2
Hmm.. I don't know but I'm willing to give it a try on my 28 apollo!
Godox/Flashpoint r2 system, plus some canon stuff.
doidinho
Feb 01, 2013 12:39 |  #3
Really nice idea. Might take a couple rolls to make something sturdy enough to last for a few shoots.
If you end up doing it be sure and document the process and do a write up.
I started sewing one a while back, but it was a slow process. In the end I ended up buying another cheap PCB grid. I bet you can make a better one with tape though.
Robert McCadden
My Flickr (external link)
MM (external link)
5DMKII, Rebel xti, 24-105 f/4L, Canon 70-200 f/4L, Canon 17-40.
Whortleberry
Joined Dec 2011
Feb 01, 2013 12:56 |  #4
You will be ASTOUNDED just how many yards of tape you need! Sticky-to-sticky, you'd need 6¼ yards just for the periphery before you even started making the grid. I looked at doing this with 3" bias binding and a sewing machine and decided against it - figuring that I wouldn't even live long enough to finish the job.
For a 3" cell size on a 28" box, there are in the region of 80 joints - more with 2" cells.
In your shoes, I'd spend the time photographing your small person and leave the grid construction to someone else.
IMAGE: http://farm9.staticflickr.com/8090/8427760871_95d495e080_b.jpg
IMAGE LINK: http://www.flickr.com …/56709879@N07/8​427760871/  (external link)
Phil ǁ Kershaw Soho Reflex: 4¼" Ross Xpres, 6½" Aldis, Super XX/ABC Pyro in 24 DDS, HP3/Meritol Metol in RFH, Johnson 'Scales' brand flash powder. Kodak Duo Six-20/Verichrome Pan. Other odd bits over the decades, simply to get the job done - not merely to polish and brag about cos I'm too mean to buy the polish!
FlickR (external link) ◄► "The Other Yongnuo User Guide v4.12" by Clive Bolton (external link) ◄► UK Railway Photographs 1906-79 (external link)
JakAHearts
Feb 01, 2013 13:10 |  #5
doidinho wrote in post #15560556 (external link)
The PDB grids arent high quality? Im going back and forth between the pro studio soluctions strip boxes or the buff ones.
Shane
bdillon
Joined Jun 2011
Feb 01, 2013 14:55 |  #6
PCB grids are just fine. No problems with mine.
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Feb 01, 2013 15:02 |  #7
Actual gaffer tape would cost more than a good grid would.
JakAHearts
Feb 01, 2013 15:25 |  #8
Are you buying gold gaffer tape? ;) 30 yards is 15 bucks. :D
Shane
gonzogolf
Gallery: 561 photos
Feb 01, 2013 15:47 |  #9
JakAHearts wrote in post #15561248 (external link)
It would take about 30 yards to make the equivalent of the large PCB (not the giant) and thats if you only used one side. If you doubled it up rather than folding it over you would need twice that. Plus the cost of velcro to attach it. I'll pass
doidinho
Feb 01, 2013 15:51 |  #10
JakAHearts wrote in post #15560661 (external link)
They are made out of cheap materials yes.
First one I had ripped the first time I took it off, so the force it takes to undo the little strip of Velcro is too much for the grid to handle.
I of course sent it right back and got a no hassle refund.
After that I started to sew one but since there at lots of cells it became evident that it would take a really long time to finish, so II aborted the project.
I have sinced purchased another PCB grid. I just take extra precautions when removing the grid now.
Robert McCadden
MM (external link)
FJ ­ LOVE
Feb 01, 2013 21:00 |  #11
you are right, and a couple of rolls of tape added to the front of the soft box won't be light weight , the problem with most grids is the material used to build them is very heavy or flimsy and weak
i use Lighttools grids and have never looked back, they are very well constructed, light weight and don't sag,the available stretch frames make them simple to put on and remove in seconds
the last thing to consider is the light control, by buying a professionally made grid (real one) you can get the exact degree of light control you are after, no guessing :cool:
https://photography-on-the.net …hp?p=12178198&p​ostcount=6
DILLIGAF about your bicycle or your gear
drvnbysound
Feb 01, 2013 21:54 |  #12
ksbal wrote in post #15560512 (external link)
I think it was almost a year ago that I saw Westcott started making these: http://fjwestcott.com …degree-grid-for-28-apollo (external link)
I use manual exposure settings on the copy machine
..::Gear Listing::.. --==Feedback==--
...A few umbrella brackets I own...
orionz06
Feb 02, 2013 20:09 |  #13
For the time spent you might be better off to take a job and use that money to buy one. I can't imagine it taking less than an hour the end result, time spent, and materials cost easily make it not worth it.
5D Mark IV~7D+BG-E7/400D~Canon 50mm f/1.8 II~EF 100mm f/2.8 L IS Macro~EF 24-70mm f/2.8L II~EF 70-200mm f/2.8L IS II~EF 50mm f/1.4 USM~Yongnuo YN-565EX ETTL~Yongnuo YN-E3-RT~Canon 600EX-RT
JakAHearts
Feb 02, 2013 20:28 |  #14
Lol. Okok. I'll just buy what I need.
Some of those light tools grids are over five hundrds bucks though. :(
Shane
datamon
Joined Dec 2012
Feb 03, 2013 05:40 |  #15
Some alternate ideas in here: http://www.modelmayhem​.com/po.php?thread_id=​812160 (external link)
3,218 views & 0 likes for this thread, 10 members have posted to it.
Gaffer tape grid
1458 guests, 128 members online
