Thread started 01 Feb 2013 (Friday) 13:01
Condensation?
Stillwater ­ Gold
Joined Jun 2012
Feb 01, 2013 13:01 |  #1
Is there a recognized outdoor temp where condensation becomes a potential problem for ones lens? I live in an area where outdoor temps are regularly in the 20's & 30's F and I'm afraid to bring my gear out fearing condensation. My inside temps are always in the 70's.
I've heard of using plastic zip-lock bags but I'm not sure exactly how this works? Does one keep all lens in a zip-lock bag inside and out? Do you keep your camera in a zip-lock bag when outside in freezing temps and after using the camera do you put it back inside the bag?
Once you're back inside when can you take your gear out of the bags?
Sorry for all the questions but I'd really like to feel comfortable using my canon 5d mkiii & lens outdoors without the fear of ruining the equipment.
Pete
archer1960
Gallery: 6 photos
Feb 01, 2013 13:12 |  #2
You put it in the bag before bringing it into a warm, more humid area. Leave it in the bag until it gets up to room temperature. This prevents condensation from getting on the equipment, and instead keeps it on the outside of the bags.
You won't get condensation from taking them outside unless you're in a situation where you might get dew or frost on them (typically with clear skies and relatively high humidity when the temperature is falling just after sunset). If you are getting dew or frost on the grass or your car, then you will likely get it on the camera equipment as well. If there's none on a car, then it won't be on your equipment either.
Gripped 7D, gripped, full-spectrum modfied T1i (500D), SX50HS, A2E film body, Tamzooka (150-600), Tamron 90mm/2.8 VC (ver 2), Tamron 18-270 VC, Canon FD 100 f/4.0 macro, Canon 24-105 f/4L,Canon EF 200 f/2.8LII, Canon 85 f/1.8, Tamron Adaptall 2 90mmf/2.5 Macro, Tokina 11-16, Canon EX-430 flash, Vivitar DF-383 flash, Astro-Tech AT6RC and Celestron NexStar 102 GT telescopes, various other semi-crappy manual lenses and stuff.
msowsun
"approx 8mm"
Gallery: 18 photos
Feb 01, 2013 14:10 |  #3
As was said. don't worry about taking the gear out into cold temperatures. It is only when when you bring cold gear into a warm environment that you could get condensation. Most homes are pretty dry, especially in the winter, so it is rarely a problem. Just leaving the gear in the camera bag to slowly warm up would probably be all the protection from humidity you need. The plastic bag trick is extra insurance, but I doubt you will need it.
Living in the tropics and going from a cool, dry Air Conditioned home to the hot and humid outdoors is where you can really see condensation happen.
Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.8 STM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
dpds68
Feb 01, 2013 15:15 |  #4
^^^ Yes thats what happens to me well used to I used to store my gear in my A/C room and every time I needed something quickly condensation all over I now store gear outside in a non A/C room ,
Life in the tropics .
David
Gripped Canon 7D,20D,XT / Tamron 17-50mm 2.8, Canon 85mm f1.8 , 70-200 2.8L,EF50mm1.8 II,Sigma 150-500mm OS, Sigma 105mm 2.8 Macro, Sigma 10-20mm 4-5.6
Vivitar285Hv x2,Canon430EX,Nissin Di866,CTR-301P Triggers,
http://www.flickr.com/​photos/dpds68/ (external link)
cor726
Feb 01, 2013 16:17 as a reply to  @ dpds68's post |  #5
I have used some of my cheaper lenses in temperatures as low as -40 - never had a problem. I have used the plastic bag before on some of the more expensive lenses just for extra insurance but I doubt it was necessary.
Our winters are very dry here.
Canon 7D, 50D, 40D, 20D and T3, Σ EX 10-20 f/4-5.6, 17-40 F/4L, Σ EX 18-50 f/2.8, 18-55 IS, 70-200 F/4L, Σ EX 30 f/1.4, 40 f/2.8 STM, 60 2.8 Macro, 85 f/1.8, 1.4x II, 430EXII
And a Canon Rebel S II & 35-80 f/4-5.6 USM
977 views & 0 likes for this thread
Condensation?
Latest registered member is tankiedog
387 guests, 263 members online
