To go with 5D Mark III (or 7D) and 580EXII and 430EX
Supports ETTL
Range up to max 30m
Reasonably priced..
I know this information may be buried somewhere on the forum.
If you have it handy, please recommend...
Feb 01, 2013 17:10 | #1 To go with 5D Mark III (or 7D) and 580EXII and 430EX
dmward Cream of the Crop More info | Feb 01, 2013 17:31 | #2 Read: https://photography-on-the.net …/showthread.php?t=1212530 David | Sharing my Insights, Knowledge & Experience
elv Goldmember 1,491 posts Likes: 181 Joined Jul 2006 More info | It depends on what you consider reasonably priced, I would agree none are better than the YN-622C for the minimum price
Feb 01, 2013 20:44 | #4 elv wrote in post #15562211 It depends on what you consider reasonably priced, I would agree none are better than the YN-622C for the minimum price ![]() I put a guide to the TTL radio triggers up here if that may be of help - http://flashhavoc.com/flash-trigger-guide-ttl/ . Yes. I am reading that thread about YN622 as the other poster suggested.
elv Goldmember 1,491 posts Likes: 181 Joined Jul 2006 More info | Well if I had a 5DIII I would spend a little extra on a nicer trigger like the Phottix Odin too
Feb 02, 2013 11:39 | #6 elv wrote in post #15562356 Well if I had a 5DIII I would spend a little extra on a nicer trigger like the Phottix Odin too The YN-622C won't control manual power levels on the 430ex, and they don't mix ETTL and manaul. They are great for the price, but there are nicer options available if you can spend a bit more. . Thanks. But for that kind of money ($300+), wouldn't ST-E3-RT makes more sense?
Roroco Senior Member 647 posts Joined Oct 2010 More info | Feb 02, 2013 16:55 | #7 rndman wrote in post #15564076 Thanks. But for that kind of money ($300+), wouldn't ST-E3-RT makes more sense? Edit : Yeah. I know. It wouldn't work even with 580EX II... The 622cs work just fine with my 580EXII and my YN568EXs. They are spectacular triggers (regardless of the price). Roger Lights -- Alien Bees B800 -- 580 EX II -- Yongnuo YN-560 II & YN-568EX -- Mother Nature -- RF 602s
elv Goldmember 1,491 posts Likes: 181 Joined Jul 2006 More info | The YN-622C are brilliant triggers, but they are still made to a price. I'd still have a lot more confidence in the Odin for something more critical, not to mention the much better interface for manual power use.
Moppie Moderator 15,102 posts Gallery: 24 photos Best ofs: 1 Likes: 451 Joined Sep 2004 Location: Akarana, Aotearoa. (Kiwiland) More info | Feb 02, 2013 18:33 | #9 elv wrote in post #15565408 The YN-622C are brilliant triggers, but they are still made to a price. I'd still have a lot more confidence in the Odin for something more critical, not to mention the much better interface for manual power use. Some people have been happy to use the 622 for weddings etc, others moved on fairly quickly. If you're confident to deal with any issue quickly is probably no problem either way, but many people are not that technically minded, they just want things to work without having to worry about that.
flickr
| Latest registered member is semonsters 1469 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
