Hello!
I plan to buy a 7D, in Summer...
It's a nice camera, I have one.
I have some questions tough:
No worries!
How exactly does the built in Speedlite Transmitter work?!
It's pretty simple.
The pop up flash sends a series of light pulses which has a bunch of information encoded into them. The slave flashes have a little sensor on the front of them that can see these pulses and decode the information. This information tells them when to fire and how strongly to fire.
- Must the built in flash be used to get it work?
Yes. The 7D uses the pop up flash to send the encoded light pulses.
- Can it fire also older flashes (420EX, 550EX)
If the slave flashes can work as a wireless slave using Canon's wireless system, they will work.
- Must it have "eye contact" with the flash, or is it with some kind of radio transmission?
The slave has to be able to see the light pulses from the pop up flash. This doesn't always mean a direct line of sight though. You can bounce the light around corners, for example.
- Can it fire, for example Studio Flashes?
Not really. As I said earlier, it's designed to work with Canon's wireless flash set up. Unless the studio lights can understand the light pulse code Canon uses, they won't fire.
A way around this is to set the pop up flash to manual and attach a basic optical slave to the studio light. This way the studio light just fires when it sees the pop up flash go off. However, you lose a lot of the functionality by doing this. For example, you lose the ability to use automatic flash, and you have to adjust the slave flash's output from the slave itself.
- How big is the reach of the transmitter?
it depends on the conditions.
On a sunny day it won't be too far. A few meters at best. On a dark night it will be further. I've managed to get mine to trigger from about 20 meters away, but that was at night, and it was using a 580EX as the master instead of the pop up flash.
- Can multiple 7D-s with Flashes be used simultaneously by different people (so that i don't fire off the flash, of the other guys)?
Yes.
Canon's wireless flash system has different channels. You can be shooting alongside another photographer, and if you are using Channel 1 and he is using Channel 2, then you won't set off each others flashes.
it depends. If you are going to be using the 600EX-RT flashes as your slaves, then you can use the ST-E3-RT as a radio trigger. This has some pretty significant advantages, as you do not need to make sure your slaves can see the master, and you can put your slaves much further away.
But the 600EX-RT is the only flash that will be triggered by the ST-E3-RT master unit. If you are using other flash units as your slave, the ST-E3 won't work. It's radio only.
There is the ST-E2 master unit, which works on the light pulse system, but you do lose some functionality with that. You don't get manual flash, and you can only control groups A and B. No group C. Using your 7D's pop up flash, you get both group C and manual flash.
Thanks guys.
No worries!
Check out this link
for my complete tutorial on how to use Canon's wireless flash system.
