Thread started 09 Jan 2006 (Monday) 15:42
G5 and Manual focusing??
Reeforbust
Jan 09, 2006 15:42 |  #1
I take tons of pictures and use the Manual focus but it is really hard to tell where your at with the focus on such a small screen......I basically guess and take extra pics just incase.
Does anyone have any secrets to using the manual focus?
Gear-list!
DSLR gallery Click (external link)~here!
Canon G5 gallery Click (external link)~here!
Bryan ­ Bedell
Jan 09, 2006 16:30 |  #2
The one thing i've learned is for close-up stuff, it's easier to move the camera around until the image is crisp (if that's an option) than fiddle with the focus.
Also, note that the MF adjustment bar is marked with distances, if you're good at judging distances, that's helpful. (It's adjustable between feet or meters)
Goofing around the other day, I noticed that you can connect to a TV (as if you were doing a slide show) and use it as a big monitor while you're shooting... If you happen to be shooting near a TV, it might make it easier to see your focus on a bigger screen
Also, read up on depth of field and hyperfocals: certain apertures and zoom ranges give you a deeper depth of field that allows you more focus wiggle room
Reeforbust
Jan 09, 2006 16:44 as a reply to  @ Bryan Bedell's post |  #3
Thanks......MAN, a T.V. sized screen would be nice!!:D
Gear-list!
pushtoexit
Joined Jan 2005
Jan 09, 2006 17:54 |  #4
There is also focus Bracket (bkt) which takes a couple extra pictures on either side of your focal point auomatically when set, or alternatively, after you manual focus, if you hit the set button the camera will start at the MF point and then search for a better auto focus for you.
A Beginners Gallery (external link)
3Dart
Joined Dec 2003
Jan 09, 2006 19:59 |  #5
I get good results if working off a tripod
1.set MF the best you can and take a shot
2.switch to display mode zoom in and search around you can easily see what is in
focus
3. press the shutter button to get back to photo mode then without touching the
focus wheel push the MF button twice and you are are right back where you left
off make appropriate adjustments and take another shot
works for me good luck
Reeforbust
Jan 09, 2006 20:18 as a reply to  @ 3Dart's post |  #6
Yeah.....I do the same sometimes, But I was wondering if there was a better and easier way to tell if your in focus. It gets old checkin your pics to make sure they look good......Get I need to jump up to DSLR????
Gear-list!
1,940 views & 0 likes for this thread, 4 members have posted to it.
2460 guests, 124 members online
