Thread started 03 Feb 2013 (Sunday) 17:43
What's Causing This In This Picture?
DavidSR
Feb 03, 2013 17:43 |  #1
Hello,
I took a picture inside of Chuck E Cheese and I noticed a blue light shining on my son's leg. My settings were f1.8 ISO 800 and shutter was around 1/100-1/200. I tried recreating it, but nothing, so what do you think caused it?
Thank you!!
T4i, 18-55mm IS, 55-250mm IS, 50mm 1.8, 3 Vivitar 285HV's and a set of Cactus V5 Triggers!!
icacphotography
Joined Jan 2013
Feb 03, 2013 17:50 |  #2
I'd say perhaps something that was on the video screen and then light was bouncing around oddly and it looks like it caused a flare in side the lens. I'd bet it was one of those "the stars align type things. Wouldn't worry too much about it. question though where you using a lens hood at all? I find sometimes even with light that's external but not coming in say at a 45 degree angle from the front it can still cause flares and a lens hood can usually block off the front element enough to prevent this.
Body:50D gripped Magic Lantern'd
Lenses:50mm 1.8,40mm 2.8,28-105 USM II,70-210 F4, 1962 Asahi Pentax Super Takumar 55mm 1.8
Flash: Canon 430 EX
The camera is just a tool - it is not responsible for the picture.
sandpiper
Feb 03, 2013 17:51 |  #3
Looks like the light shining from the screen to me. It's shining on his face as well.
TSchrief
Joined Aug 2012
Feb 03, 2013 18:10 |  #4
Light from the LCD screen or reflections off a filter.
pulsar123
Gallery: 82 photos
Feb 03, 2013 18:15 |  #5
It looks like this is a lens flare, from the bright window. The bluish blob extends beyond the legs - on the chair, and on the wall behind, so not likely a local source of blue light.
Was a filter on the lens? They tend to magnify flare problems.
6D (normal), 6D (full spectrum), Tamron 24-70 f2.8 VC, 135L, 70-200 f4L, 50mm f1.8 STM, Samyang 8mm fisheye, home studio, Fast Stacker
kouasupra
Feb 04, 2013 01:23 |  #6
Yes it looks like a lens flare. Were you using a lens hood?
pulsar123
Gallery: 82 photos
Feb 04, 2013 08:03 |  #7
If this is indeed a lens flare, hood most likely won't help, as the cause of the flare (bright window) is right inside the frame. To avoid it then you'd indeed have to use the hood and don't use a filter and make sure there are no too bright light sources inside the frame.
davidc502
Feb 04, 2013 09:45 |  #8
That's not from the blue LCD screens in front of him? I noticed it in his eyes as well.
_
My Gear is ---> Here
krb
Feb 04, 2013 10:03 |  #9
The color of blue in his eyes looks like the correct shade of blue for indirect sunlight when you are shooting indoors with a tungsten white balance.
-- Ken
Gear list
Keyan
Joined Mar 2011
Feb 04, 2013 10:34 |  #10
I think it's a combination. The blue on the face is probably from the screen.
The blue that is lower is lens flare from the windows. A cheap filter and some lenses will cause this easily, I would be interested to know what the lens setup was.
Cameras: 7D2, S100
Lenses: 17-55 f/2.8 IS USM, 18-135 STM, 24-70 f/4L IS USM, 50 f/1.4 USM,70-300L IS USM
Other Stuff: 430 EX II, Luma Labs Loop 3, CamRanger
1,427 views & 0 likes for this thread, 9 members have posted to it.
1600 guests, 140 members online
