Thread started 09 Jan 2006 (Monday) 17:30
This is driving me crazy...
MALI
Jan 09, 2006 17:30 |  #1
Help! :( In Photoshop Elements 3, I somehow changed the background color of the image window to black from the original grey and now I want to change it back but I can't. How do I do that? Thanks.
MALI
Canon 20D, 10-22, 24-70L,70-200L f/2.8 IS, 580 EX, RS-80N3, EP-EX15, BG-E2, E1.
jfrancho
Jan 09, 2006 18:14 |  #2
Hit the d key.
jfrancho
Jan 09, 2006 18:16 |  #3
I'm sorry, I misread that! The d key resets the swatches to default. It should be in Edit>Preferences. Sorry about that!
MALI
Jan 09, 2006 18:24 as a reply to  @ jfrancho's post |  #4
It is not there. :cry:
MALI
jfrancho
Jan 09, 2006 18:30 |  #5
Check your Display settings in the control panel, then.
MALI
Jan 09, 2006 19:01 |  #6
This is what I mean. Look at the image I attached. The picture I am working on in the middle is covered by space, which I turned into black and I do not remember how. It used to be grey. I need it grey again because when the pictures I am working on have dark colors around the edges, I cannot see where the image ends.
Does anyone know how I make that spce grey again?
Thanks.
MALI
jfrancho
Jan 09, 2006 19:02 |  #7
Hit f and see if that changes it?
MALI
Jan 09, 2006 19:06 as a reply to  @ jfrancho's post |  #8
Nope. I vaguely remember that I used some key combination like CTRL + something but I forgot. I have been trying all the combinations I can think of but did not succeed so far. The more I try hard to think what it was, the more blank my mind goes. Grrrh.
MALI
jfrancho
Jan 09, 2006 19:08 |  #9
Anything, like View>Screen Mode?
MisterJP
Jan 09, 2006 21:47 as a reply to  @ jfrancho's post |  #10
This works in Photoshop:
1) Make gray your foreground color in the tool palette
2) Pick the Paint Bucket Tool
3) Shift-Click in the background
Should change the window background color to the foreground color. Hope this works!!
______________
www.johnpischke.com (external link)
Canon 5DIII & 5DII • Canon 50 1.4 •
Canon 16-35 2.8L IICanon 24-70 2.8LCanon 100 2.8 Macro • Canon 70-200 2.8L IS • Canon 100-400L • Elinchrom Lights
jfrancho
Jan 09, 2006 22:08 |  #11
Well that fills a background layer of an image, but it doesn't change the application work area.
MisterJP
Jan 09, 2006 22:26 as a reply to  @ jfrancho's post |  #12
See picture for example . . . when I shift-click (on a Mac) on the red x'd areas with the Paint Bucket tool selected, it changes the window background color to the foreground color in the tool palette.
If that doesn't work for Elements, try the forums on the Adobe website?
______________
jfrancho
Jan 09, 2006 22:30 |  #13
Yes, but that is in the image window, what about the application work area? It looks like MALI's is black, like if you hit 'f' twice and changed the screen mode.
MisterJP
Jan 09, 2006 22:37 as a reply to  @ jfrancho's post |  #14
That is the application work are, when the image window is pulled out bigger. That techniques works the same with the first two "F" modes, but not the full screen option . . . that is always black. Could just be a Photoshop-only function?
______________
jfrancho
Jan 10, 2006 07:35 |  #15
I think what you posted in #12 is probably it. I noticed that if you change the window background, using the Shift-Click fill, and then hit f once, that new color is there. But if you hit "f' again, it goes black - like it should. I suppose MALI could go and reset the Display properties in teh Windows Control Panel (after saving his current desktop as a theme, of course) and select a default theme and see if that returns it to normal. Otherwise I have no idea. I'm sure there is a simple explanation.
1,915 views & 0 likes for this thread, 3 members have posted to it.
2234 guests, 127 members online
