Thread started 04 Feb 2013 (Monday) 09:04
CS5 adding Fringing and other junk... Can this be avoided?
sticknpuck
Feb 04, 2013 09:04 |  #1
First off - this may or may not be a problem. Of course, I wish it weren't happening but I have a feeling this just may be a limitation of file size or photoshop software. Could also be these damn Fuji files, or the DNG conversion i'm not sure. I know these crops are totally unrealistic and that I shouldn't peep but the DNG file is so clean, I really would like the .psd to look like that!
The two crops below show exactly the problem.
First the DNG file converted from X-E1 RAF file. Nice and clean. No issues at all from the 18-55 zoom. Really pretty impressive.
Second, the same crop from the PSD file when imported to CS5.
Bad fringing and that grid overlay which I presume is CS5 throwing all that detail away on import.
I know this isn't a problem at normal viewing sizes, but if I wanted to clean up some of the image - Scotiabank sign and garbage on the ground, and print this large do these details become noticeable or am I expecting too much?
Thanks for looking.
Matt
tonylong
...winded
Gallery: 60 photos
Feb 04, 2013 11:22 |  #2
Hmm, the artifacts do look strange -- what exactly was your workflow, and are seeing this consistently?
Tony
sticknpuck
Feb 04, 2013 11:43 |  #3
My workflow is import RAF files into LR4, convert to DNG using adobe DNG converter, from LR4 - edit photo in CS5. Camera Raw can't open RAF files (the latest version can but i'm not upgrading), that's why I have to convert to DNG.
If it's been a problem I haven't noticed it before. mind you, i've never had to convert to DNG before either. The Fuji is new to me though so I haven't had much time editing these RAF files so this could be a camera specific issue. Does seem odd though the DNG file looks perfectly acceptable only to be butchered by CS5.
Matt
Redcrown
Feb 04, 2013 12:16 |  #4
Can't tell much from your samples. Suggest you upload the original raw somewhere (Dropbox?) so others can process it to see if they get the same results.
tonylong
...winded
Gallery: 60 photos
Feb 04, 2013 12:22 |  #5
I'd second the above suggestion. Then, when you Edit in Photoshop, the image has to go through a second conversion. Maybe try opening the DNG directly in Camera Raw via Bridge and see what you see in Camera Raw when zoomed in before it converts to the psd...?
Tony
sticknpuck
Feb 04, 2013 12:38 |  #6
Ok i'll try uploading the RAW file when I get home. I would assume that it looks fine in Camera Raw just as it does in Lightroom. It's the conversion into psd that it gets messy. I will also try Fuji's raw processor - Silkypix - to see if that helps.
Thanks guys.
Matt
René ­ Damkot
Feb 04, 2013 17:05 |  #7
Is the first image ("DNG file converted from X-E1 RAF file") a screenshot or the file exported from LR?
Certainly shouldn't come out like the second screenshot.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
tzalman
Fatal attraction.
Feb 04, 2013 17:39 |  #8
Here is a comparison of a dng (generated from a CR2) and a psd generated from the dng and opened in PSCS2.
Elie / אלי
sticknpuck
Feb 04, 2013 17:42 |  #9
René Damkot wrote in post #15572241 (external link)
Hi René,
Those are crops exported as jpgs from LR4 - no screenshots, and look exactly as they do on my monitor in LR4.
I just tried silkypix but it only converts to jpg or tiff.
The file can be downloaded here with code NV9QQ if anyone wants to give it a shot.
http://efshare.com/?s=​7J4ACR (external link)
Matt
Redcrown
Feb 04, 2013 22:15 |  #10
I downloaded your raw and converted it to DNG using the latest DNG Converter (7.3).
Then I banged away on it with CS6 and CS5, using every option I could think of to "break" it, but nothing I did created the fringing and grid pattern shown in your example. I tried different "process versions" of ACR, different color profiles, strong sharpening, lens profile correction, NR, clarity, etc. They all worked as I expected, but no fringe or grid.
The grid pattern looks similar to what I see sometimes with HDR programs or other "tone mappers" like Topaz, but I can't get it on this image using ACR and Photoshop.
I don't use Lightroom, and would not expect it to be the culprit, but I'd recommed you bypass Lightroom and see if the same problem exists. Open the dng directly in CS5, save as a PSD, re-open the PSD in CS5 and see if the problem is still there.
sticknpuck
Feb 04, 2013 22:27 |  #11
Thanks Red, did you use Adobe DNG converter or the latest version of ACR? I don't have the latest version of ACR which is why I had to use the Adobe converter.
Thanks very much for taking the time to run those tests - much appreciated. All for a Fuji user no less. This forum is class.
I'll try by passing lightroom and let you know what happens.
Cheers
Matt
tonylong
...winded
Gallery: 60 photos
Feb 05, 2013 00:21 |  #12
sticknpuck wrote in post #15573384 (external link)
Cheers
Maybe youi should be very specific about your workflow:
When you convert to DNG as part of your import into Lightroom, or do is separately?
How do you open the image in the Photoshop editor?
Please fill in any details in your steps along the way: what processing do you do in Lightroom, for example?
Tony
sticknpuck
Feb 05, 2013 01:37 |  #13
tonylong wrote in post #15573702 (external link)
1. SD card inserted into PC
2. LR4 opens to import
3. RAF files imported into LR4
4. Open Adobe DNG converter and convert files in that folder
5. Synchronize folder in LR4
I have tried every which way at this point of getting it into CS5 - photo>edit> in CS5, open file in explorer> open with CS5 it does not seem to matter. I am 90% certain this is an issue with the DNG converter. I re-checked my older 60D files and none of them show these issues.
Tomorrow I will try a 60D RAW file converted in Adobe DNG converter and see what happens. It's gotta be something to do with Adobe's lackluster support of the x-trans RAF files.
Matt
tonylong
...winded
Gallery: 60 photos
Feb 05, 2013 01:41 |  #14
OK, try setting your LR Import to convert to DNG, using a "current" DNG converter.
Tony
BigAl007
Gallery: 542 photos
Feb 05, 2013 06:05 |  #15
As you have LR4 why not just use that for your RAW conversion and do away with the convert to DNG? LR has the exact same tools as ACR, in fact if you are using LR4 and an older version of PS then LR gives you the option of using the new Process 2012 as well. Apply all of your RAW conversion settings in LR and then just use the export to PS option if you need to do any pixel level editing. I cannot see any reason why you would need to go LR4 > convert to DNG > ACR > PS when you can go directly from LR4 > PS.
Alan
My Flickr (external link)
2,745 views & 0 likes for this thread
Latest registered member is dayuan99
1653 guests, 314 members online
