Thread started 04 Feb 2013 (Monday) 17:01
Probably a stupid question, but...TC's & non-primes
Ace ­ and ­ Deuce
Joined Feb 2012
Feb 04, 2013 17:01 |  #1
I am under the assumption that a 1.4 or 2x teleconverter can only be used on prime lenses...is this true? Also, are only the Canon TC's compatible? I currently have a Bower 2x, and while I know it doesn't work with any of my zooms, I am getting a 100-400L this week, so will my Bower, or a Canon TC, work with this lens?
Thanks,
~Ace
Nightdiver13
Unabashed nerd!
Feb 04, 2013 17:12 |  #2
Check the TC FAQs. Most of your answers can be found there. Short answer: No, they aren't limited to primes. They will work with a 100-400 but not with AF.
Neil
JeffreyG
Gallery: 42 photos
Feb 04, 2013 17:13 |  #3
Ace and Deuce wrote in post #15572229 (external link)
Nope. Canon TCs are also compatible with the 70-200Ls and the 100-400L. There may be a few other zooms that escape my recollection.
Thanks,
~Ace
The 100-400L is compatible with both Canon and 3rd party TCs. It will not autofocus with a (reporting) 2X TC on any body, and it will only AF on a 1D body using the center point with a 1.4X TC.
Ace ­ and ­ Deuce
Joined Feb 2012
Feb 04, 2013 17:15 |  #4
Awesome, thank you, gentlemen!!
1Tanker
Feb 04, 2013 17:18 as a reply to  @ Ace and Deuce's post |  #5
If you do decide to go for a 1.4x TC, i'm going to suggest a non-Canon....so you can use it on your 100 macro! :D
Kel
Gear
Ace ­ and ­ Deuce
Joined Feb 2012
Feb 04, 2013 17:20 |  #6
I use my 2x Bower on my 100 macro all the time...is there a difference with the 1.4?
1Tanker
Feb 04, 2013 17:30 |  #7
Ace and Deuce wrote in post #15572302 (external link)
Just one less stop of light-loss, and less hit on IQ. Both my TC's are Sigma's, but the 2x won't AF on my 100 macro ( which doesn't matter much...for macro) and theoretically it should ( f/5.6). I find the 1.4 still makes the 100 a nice lens to walk around with, for shooting plants, etc., while still maintaining AF and decent IQ.
If you only use your 100 macro for macro, then i wouldn't consider it. Just that, if you were to get a 1.4x for the 100-400, IMO.. you might as well get one that does double-duty. ;)
Kel
Gear
Ace ­ and ­ Deuce
Joined Feb 2012
Feb 04, 2013 17:44 |  #8
OK, I'm a bit confused now. If I have a 2x that works with my 100mm macro, which I do use for some walk around stuff (I never use AF with this lens, anyhow), and it will work with my 100-400 when I get it, what would the benefit of having a 1.4x be?
After grabbing my 100-400, I'm going to have around $600 to play with. I was considering these options:
70-200L non-IS ($558) - Do I really need it with a 100-400, even if I sell my 55-250 & 75-300?
18-135 IS ($449) - I could sell my 18-55, 55-250, and 75-300
manfrotto tripod w/ball grip ($330) - my current one sucks
another 430 EXII ($219) - Just bought some umbrellas/stands/mount​s
another bag to house lenses & camera ($100) - can't even keep my camera in the bag anymore
Do I need to consider a 1.4x?
RobDickinson
Gallery: 14 photos
Feb 04, 2013 17:52 |  #9
1.4 only drops a stop of light and generaly impacts optical and autofocus less.
Canon TC's wil work with every prime 135L and up, the tilt shifts and 70-200/100-400 zooms
www.HeroWorkshops.com (external link) - www.rjd.co.nz (external link) - www.zarphag.com (external link)
Gear: A7r, 6D, Irix 15mmf2.4 , canon 16-35f4L, Canon 24mm TS-E f3.5 mk2, Sigma 50mm art, 70-200f2.8L, 400L. Lee filters, iOptron IPano, Emotimo TB3, Markins, Feisol, Novoflex, Sirui. etc.
DreDaze
Gallery: 49 photos
Feb 04, 2013 19:18 |  #10
i would expect the 2X to work on your 75-300mm...and by work i mean fit
Andre or Dre
gear list
Instagram (external link)
Ace ­ and ­ Deuce
Joined Feb 2012
Feb 04, 2013 19:28 |  #11
DreDaze wrote in post #15572740 (external link)
Wow, it does fit!! Autofocus worked as well, but my aperture wouldn't go too high. Can't wait to play around with it tomorrow in some light.
jimewall
Feb 04, 2013 19:31 |  #12
1Tanker wrote in post #15572338 (external link)
That is weird, the 2X on a 100mm f/2.8 macro (or f/2.8) any lens should AF. It would AF slower and sometimes less accurately, but it should still AF.
AF should work on any lens f/2.8 or faster. As long as the combined aperture is f/5.6 or wider on an Canon AF lens, it should work on any Canon camera body.
Do you have any idea of why it does not on yours?
For the OP. The other difference between the 1.4X and the 2X, is the 2X usually affects the IQ of the image much more negatively than a 1.4X. That is not to say you can't get good and usable pictures, but if compared there is usually more IQ loss. To me a 2X is a last resort (just in case) item, for when you have no other way to get the shot. A 1.4X is (to me) much more useful.
Thanks for Reading & Good Luck - Jim
GEAR
1Tanker
Feb 04, 2013 20:17 as a reply to  @ jimewall's post |  #13
I have no idea, Jim! :cry: It kind of defies all logic. It can't be a fault with the TC, as using it on my 300/4L IS on my 1D II AF's.
It just keeps hunting, racking back and forth(on the 100); get's soooo close, then keeps going again. I don't now.. maybe it's an issue with the lens itself, as it hunts a bit too much for my liking with the 1.4x also, at closer(<5') distances; and yes.. that's with focus limiter set properly.
Kel
Gear
jimewall
Feb 04, 2013 20:26 |  #14
1Tanker wrote in post #15572921 (external link)
That is a bit peculiar.
I don't remember a problem with my 100mm f/2.8 (non-L non-USM) with a 1.4X, I will give it a try with my Kenko 1.4X and 2X (I don't think I ever used this and AF on my macro - but I will) on Wednesday night and report back. I'm not feeling well tonight and am going to bed, and I will not be home until late tomorrow.
Anybody else have problems with a TC and their 100mm macro lens?
GEAR
Ace ­ and ­ Deuce
Joined Feb 2012
Feb 04, 2013 20:33 |  #15
I just checked my Bower 2x on my 100mm USM non-L macro. Works perfectly, auto-focuses @ 5.6
1,829 views & 0 likes for this thread, 7 members have posted to it and it is followed by 2 members.
903 guests, 118 members online
