FORUMS Community Talk, Chatter & Stuff Photography Industry News
Thread started 07 Feb 2013 (Thursday) 01:32
Make Your DSLR Camera Run Four Times Longer with a DIY External Battery System
Moin
Feb 07, 2013 01:32 |  #1
http://www.diyphotogra​phy.net …attery-run-4-times-longer (external link)
Though, I'm not sure if I can do this ..
flickrr (external link)
Instagram (external link)
watt100
Feb 07, 2013 08:54 |  #2
Moin wrote in post #15581893 (external link)
interesting but doesn't look like the easiest DIY photo project
Turning
Feb 07, 2013 11:17 |  #3
I know it's off thread, but it drives me crazy when people say 4 times longer when it's really 4 times as long.
rick_reno
Feb 07, 2013 11:43 |  #4
I think I'd stick with the red wagon, my AC generator and an AC adapter. I've got to give the author an A+ for creativity with this one.
Chet
Gallery: 132 photos
Feb 07, 2013 11:47 |  #5
Turning wrote in post #15583159 (external link)
I don't see a difference.
tkbslc
Feb 07, 2013 13:28 |  #6
4x longer technically = 500%
4x as long = 400%
Taylor
EOS Rp | iPhone 11 Pro Max
ZXDrew
Feb 07, 2013 14:34 |  #7
tkbslc wrote in post #15583576 (external link)
4x as long = 400%
He is correct on this one.
PhotoWolfe.com (external link)
Facebook.com/PhotoWolfe (external link)
Gear / My flickr (external link)
Hillbille
Joined Nov 2010
Feb 07, 2013 14:34 as a reply to  @ tkbslc's post |  #8
I have thought of this as I was thinking of doing some time lapse over an extended period. My solution was a bit different though as instead of opening the OEM battery and going that route I chose to get a cheap grip off e-bay and simply wire the battery tray. I figured that I would never use the AA tray anyway so I did essentially the same thing using that. That way I can unscrew the grip (or replace the tray) and never need to take a chance of harming the camera.
Hillbille
Rebel T2i, XS, Rebel T3; EF-S 70 - 300mm non L; EF-S 55 - 250mm; 50mm 1.8; 18 - 55 kit; YN-560; YN-468 - Pure Fun and Raw excitement.
tkbslc
Feb 07, 2013 15:13 |  #9
ZXDrew wrote in post #15583790 (external link)
But I only pointed it out because someone asked. I generally don't make a point of correcting people unless precision is relevant.
Back to the topic at hand, I always found it easier to give my camera longer running time by just carrying some extra (no-name) batteries.
Taylor
Hillbille
Joined Nov 2010
Feb 07, 2013 16:17 |  #10
tkbslc wrote in post #15583920 (external link)
In the case of time lapse you really do not want to disturb the camera changing batteries. Therefore it is far better to have an external power supply that can be changed or extended without disturbing the camera in order to maintain the exact line of shooting. Carrying extra batteries works for normal use but isn't always THE way to go in all uses.
Hillbille
Mark1
Feb 07, 2013 16:50 |  #11
Why not just buy the AC adapter? After you buy everything and take the time to put it all together Id just buy the adapter.
Hillbille
Joined Nov 2010
Feb 08, 2013 00:30 |  #12
Mark1 wrote in post #15584326 (external link)
For me the entire project was not intended to use an AC adapter at all but was intended to use an external set of batteries which could be run in parallel via a double connector and thus allowing one (battery)to be replaced while another provided power. Larger capacity batteries allowed for extended shooting away from the normal "grid" and out where I wanted to be.
Hillbille
Luckless
Joined Mar 2012
Feb 08, 2013 11:03 |  #13
This seems like a fire waiting to happen. I especially dislike his attempt at mixing unbalanced cells in a battery circuit without including safety controls to ensure load balance, as this is a great way to fry stuff.
Personally I would rather modify an AC adaptor feed to run directly off a large capacity battery. You shouldn't need to go playing around with lithium cells and blades or soldiering irons.
Canon EOS 7D | EF 28 f/1.8 | EF 85 f/1.8 | EF 70-200 f/4L | EF-S 17-55 | Sigma 150-500
Flickr: Real-Luckless (external link)
_igi
Joined May 2011
Feb 14, 2013 05:04 |  #14
I wouldn't mount that in my 5DII, never, ever :-)
5DIV | 1DsIII x2 | 1DIV | TS-E17/4L | TS-E 24/3.5LII | 24L | 35L | 50L | 100L | 135L | 24-105L | 28-70/2.8L | 100-400L
4,349 views & 0 likes for this thread, 11 members have posted to it.
1599 guests, 139 members online
