Just a quick Q. Will a pocket wizard fire a Canon 600RT flash. Looking to do some off camera flash stuff.
scpictaker Goldmember ![]() 1,385 posts Likes: 9 Joined Feb 2009 Location: Edgerton Wis More info | Feb 07, 2013 17:39 | #1 Just a quick Q. Will a pocket wizard fire a Canon 600RT flash. Looking to do some off camera flash stuff. My Flickr
Feb 07, 2013 18:06 | #3 I thought that was the advantage to buying a radio transmitted flash? My Flickr
dedsen Goldmember ![]() 2,580 posts Likes: 27 Joined Aug 2006 More info | Feb 07, 2013 18:16 | #4 If you mean one PW on the camera and another connected to the flash, yes.
Feb 07, 2013 20:04 | #5 I was trying to find a cheaper alternative to the st-e3. But I guess I'll just have to get that then. My Flickr
PaulMedik Senior Member 541 posts Likes: 1 Joined Oct 2011 Location: West Virginia More info | Feb 07, 2013 20:12 | #6 scpictaker wrote in post #15584948 ![]() I was trying to find a cheaper alternative to the st-e3. But I guess I'll just have to get that then.
My Flickr
Feb 07, 2013 20:14 | #7 So, if I got a st-e3, I can fire my 600rt, and use my 580 exii and 430 ex as slaves to the 600rt right? So get all 3 to fire or would the later 2 just be paper weights? My Flickr
john_galt Senior Member 576 posts Likes: 2 Joined Mar 2011 More info | Feb 07, 2013 20:38 | #8 PaulMedik wrote in post #15584980 ![]() scpictaker, I have two 600EX-RT flashes; one will fire the other via master > Slave via radio. I also have an ST-E3 whatever you call it and it will fire both, but given that it's half the price of a 600EX-RT, you'd be better off buying a second flash to use as trigger IMO (And I wish I'd have thought of that before buying the $T thingamajig.) The best thing about triggering with flash is that my 5DIII can control the entire thing whereas the ST thing takes some of the control away and insists on controlling things itself...if that makes any sense. Why'd they name the ST trigger what they named it? It's too hard to remember the name. ![]() can the on camera 600 trigger the off camera slave without actually firing? or is it optically triggerd? Gear: 5d iii, 17-40mm l, 24-70mm ii, 35mm 1.4 l, 50mm 1.4, 85mm 1.8, 135mm l, 70-200mm ii l, 600ex-rt
PaulMedik Senior Member 541 posts Likes: 1 Joined Oct 2011 Location: West Virginia More info | Feb 07, 2013 22:39 | #9 john_galt wrote in post #15585068 ![]() can the on camera 600 trigger the off camera slave without actually firing? or is it optically triggerd?
My Flickr
digital paradise I still have 8 digits left ![]() More info | Feb 08, 2013 00:49 | #10 scpictaker wrote in post #15584987 ![]() So, if I got a st-e3, I can fire my 600rt, and use my 580 exii and 430 ex as slaves to the 600rt right? So get all 3 to fire or would the later 2 just be paper weights? No. Unfortunately the STE3 is RT capable only. So it won't fire any pre 600 series flashes. The 600 is both RT or OT capable so you need one of those on your cam however then you are using Optical. Canon gets you on this one. Gets you spending money. Image Editing OK
dmward Cream of the Crop More info | Feb 08, 2013 14:34 | #11 digital paradise wrote in post #15585784 ![]() Mind you if you can wait Yongnuo and others won't be far behind. Then again they may use their own radio frequency. While Yongnuo may reverse engineer the -RT function and then build 600EX-RT knock-offs, they may also opt to incorporate the YN-622c capabilities into a flash. Remember the -RT functions are only useful, in totality to 2012 cameras. On the other hand, the YN-622c is useful to any camera with external flash menu functions. David | Sharing my Insights, Knowledge & Experience
apersson850 Cream of the Crop ![]() More info | Feb 08, 2013 17:03 | #12 PaulMedik wrote in post #15584980 ![]() Why'd they name the ST trigger what they named it? It's too hard to remember the name. ![]() S(lave flash)T(rigger) - E(-TTL compatible version)3 - R(adio)T(rigger compatible) Anders
digital paradise I still have 8 digits left ![]() More info | Feb 08, 2013 17:08 | #13 Wow. I just thought they did that so it would be long and more irritating to type when in the forums. Image Editing OK
Feb 08, 2013 23:56 | #14 scpictaker wrote in post #15584987 ![]() So, if I got a st-e3, I can fire my 600rt, and use my 580 exii and 430 ex as slaves to the 600rt right? So get all 3 to fire or would the later 2 just be paper weights? I have three of the 600EX-RT flashes and one ST-E3. I've never used the ST-E3 (literally never) and would be willing to sell it to you for $295 shipped. the site
dmward Cream of the Crop More info | Feb 09, 2013 08:37 | #15 PaulMedik wrote in post #15585443 ![]() John_galt, It's triggered via radio; not optically. I'm sure there's a setting to trigger the slave though not fire the on camera master flash, but I've not found it. ![]() The left most button on the 600, in Menu 1, controls the on-camera flash output. press it to turn flash off, press it again to turn flash on. There is an icon of the flash head, with and without 3 light "rays" without means flash off, with means flash on. David | Sharing my Insights, Knowledge & Experience
y 1600 |
Log in Not a member yet?
Registered members may log in to forums and access all the features: full search, image upload, follow forums, own gear list and ratings, likes, more forums, private messaging, thread follow, notifications, own gallery, all settings, view hosted photos, own reviews, see more and do more... and all is free. Don't be a stranger - register now and start posting! |
Latest registered member is sandywalkler 904 guests, 301 members online Simultaneous users record so far is 15144, that happened on Nov 22, 2018 |
