This post is marked as spam.
dmtheblue Hatchling 5 posts Joined Feb 2013 More info | Feb 08, 2013 03:00 | #1 Permanent banSPAM PUT AWAY This post is marked as spam. |
cheermom02 Member 70 posts Joined Jan 2012 Location: hampton roads, va More info | Feb 17, 2013 20:35 | #2 you could always do the laying on each others backs...
jdpence Senior Member 584 posts Joined Jul 2008 Location: Atlanta, GA More info | Feb 21, 2013 11:41 | #3 Have them lay on their backs with heads together, bodies rotated 120 degrees from each other and shoot them from overhead. Jeremy
JoeRavenstein Goldmember 2,338 posts Likes: 1 Joined Mar 2010 Location: E Tx More info | Feb 21, 2013 12:32 | #4 I have had my granddaughters use a stepladder and posed them (7) around and on the ladder. Canon 60D,18-55mm,55-250mm,50mm compact macro, AF ext tubes. Sigma 8-16mm uwa, 18-250mm, 85mm F1.4, 150-500mm
flipnduc Member 103 posts Joined May 2011 Location: Northern VA More info | Mar 25, 2013 11:45 | #5 jdpence wrote in post #15636108 Have them lay on their backs with heads together, bodies rotated 120 degrees from each other and shoot them from overhead. ive done this before comes out great.
Pshaun Member 75 posts Joined Jul 2011 More info | Mar 28, 2013 20:29 | #6 I have had the older 2 arm wrestle with the younger behind the hands.... always nice. Works better with boys of course
darelmiler Mostly Lurking 12 posts Joined Jun 2013 More info | Jun 04, 2013 04:28 | #7 I think you have a take group unfold naturally photos. For example, you could pose the group on a staircase so they are all sitting on different steps. This will easily break up any patterns of head levels so the group looks like one and no pattern distracts the viewer. You could do the same thing by placing the group on fallen down logs or on boulders or any other uneven surface. Engagement Photographers Charleston SC
mikeyyah Member 48 posts Joined Jun 2013 Location: NYC More info | Jun 10, 2013 10:49 | #8 try having them lie down on their stomachs. Feedback:
| Latest registered member is Thunderstream 1238 guests, 121 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
