Thread started 08 Feb 2013 (Friday) 16:37
Card Reader Failes to reset in Windows -- requires reboot between cards
hairy_moth
Feb 08, 2013 16:37 |  #1
I have a problem with Windows, that I have had intermittently for years, and was wondering if others have had it and if anyone has found a better work around.
My Multi-card reader does not reset when I remove a CF card. Then, when I add another card, it is not recognized. I have no choice but to reboot before using it again. Sometime, going into the properties dialog and disabling and re-enabling the device works, but most times it does not.
Has anyone figured out how to prevent this, or a good work around?
Before removing a card, I always 'right click' the drive and hit 'eject' and wait fort the 'safe to remove' popup before removing it.
I used to use the 'Safely Remove Hardware and Eject' option from the 'notification' area of the start bar, but that would often disable the entire multi-card reader and not allow me to use it at all (USB, san, etc.) again without a reboot. The 'eject' option has been working pretty well, but recently, it has started to fail again -- I get the popup saying it is safe to remove the card, but when I do and add another.. nothing. I have had this problem, off and on, for years, with various versions of windows (now windows 7 64 bit). It seems like when it works, it works consistently for months, and then when it begins to fail, it fails consistently for moths.
Any help would be appreciated!
7D | 300D | G1X | Tokina 11-16mm f/2.8 | EF-S 17-55mm f/2.8 | EF-S 60mm f/2.8 Macro | EF 85mm f/1.8 | 70-200 f/2.8L MkII -- flickr (external link)
ebjo
Feb 08, 2013 17:08 |  #2
I had a card reader (even with no card)that if I left plugged into my computer the computer would fail to boot. was told computer was trying to boot from card reader(?) so I bought different brand and no more problems. maybe we sorta have the same issue and some one will cure it.
Rebel, 40D, 7-70 DC macro2.8-4.70-200 2.8 APO Sigma lens, 600EX-RT, 800 mm Bauch and Lomb scope.
hairy_moth
Feb 08, 2013 17:58 |  #3
Thanks for the reply.
Mine is a different problem though.
Your problem could have been fixed by going into the BIOS menu during start-up and changing the boot order so that the machine always tries to boot from the hard drive first.
It is frustrating.
Jon
Joined Jun 2004
Feb 08, 2013 18:03 |  #4
Try opening "Computer", right-clicking on the drive representing your CF card and choosing "Eject" there. If you use "Safely Remove Hardware", it'll safely remove the card reader, hence you need to reinstall it. I use USB Safely Remove (external link), which lets me choose whether to eject the card or the device.
Jon
Cocker Spaniels
1,155 views & 0 likes for this thread, 3 members have posted to it.
910 guests, 122 members online
