For those who have any of the below lenses and use FoCal, how does the resolution below compare to your tests?
I was a little disappointed in the 50L and 24L. I also really wish I kept the 35L long enough to test it against my new Sigma 35.
Feb 08, 2013 19:25 | #1 For those who have any of the below lenses and use FoCal, how does the resolution below compare to your tests?
Feb 08, 2013 19:28 | #2 BTW, these results were on a 5D MkII after applying the recommended micro-adjustment.
Feb 08, 2013 19:31 | #3 pixel peeping is a deadly disease Sony A7siii/A7iv/ZV-1 - FE 24/1.4 - SY 24/2.8 - FE 35/2.8 - FE 50/1.8 - FE 85/1.8 - F 600/5.6 - CZ 100-300 - Tamron 17-28/2.8 - 28-75/2.8 - 28-200 RXD
True. I'm just checking to see if I have a bad copy of the 24L or 50L. It's hard to know when you have no alternatives to use for a comparison.
Feb 08, 2013 19:55 | #5 Kylemorgan88 wrote in post #15588971 True. I'm just checking to see if I have a bad copy of the 24L or 50L. It's hard to know when you have no alternatives to use for a comparison. They are both under warrantee, so it won't cost me anything to get them checked. I just don't want to waste Canon's time and drive up prices for everyone else if these resolutions are typical. that's the biggest problem with this software IMO. Sony A7siii/A7iv/ZV-1 - FE 24/1.4 - SY 24/2.8 - FE 35/2.8 - FE 50/1.8 - FE 85/1.8 - F 600/5.6 - CZ 100-300 - Tamron 17-28/2.8 - 28-75/2.8 - 28-200 RXD
The resolution data is somewhat meaningless, but the MA feature is very useful.
Charlie- I see you have the 50L. Did you run the aperture sharpness test?
n1as Goldmember 2,330 posts Likes: 25 Joined Oct 2007 Location: Salem, OR More info | Feb 08, 2013 20:28 | #8 We know all of these lenses are very sharp. What this tells me is that we can definitely over measure. More sharpness from the lens does not necessarily mean your final print or web image will be any sharper. - Keith
Invertalon Cream of the Crop 6,495 posts Likes: 24 Joined Jun 2009 Location: Cleveland, OH More info | Feb 08, 2013 21:29 | #9 |
Feb 09, 2013 05:51 | #10 Invertalon wrote in post #15589302 You can't compare your resolution results with anybody else unless they had the same printer, paper, distance to target, lighting and camera body among other variables to be able to even remotely compare. There is no way. This cannot be emphasised enough. As soon as I saw those numbers down the Y-axis I new this would happen. Frank Hollis - Retired mass spectroscopist
pulsar123 Goldmember More info | Feb 09, 2013 05:57 | #11 Well, one thing can be compared - the maximum sharpness aperture, which should be fairly immune to light, target, and even camera variations (as long as these apertures are still far from the diffraction limit imposed by the sensor). It is not a very useful parameter, though. 6D (normal), 6D (full spectrum), Tamron 24-70 f2.8 VC, 135L, 70-200 f4L, 50mm f1.8 STM, Samyang 8mm fisheye, home studio, Fast Stacker
Feb 09, 2013 06:21 | #12 pulsar123 wrote in post #15590090 It is not a very useful parameter, though. Yes, optimum aperture can be compared, but I would disagree about its usefulness. I think it's quite handy to know which of my lenses are totally crap when used wide-open and which are OK. Yes, experience gives me a good idea - eventually - but I do like having the hard data to back up what I thought was correct. So now I try to always have my 300 f2.8 +1.4x TC at f4.5 instead of f4. Frank Hollis - Retired mass spectroscopist
Feb 09, 2013 08:29 | #13 Kylemorgan88 wrote in post #15588913 For those who have any of the below lenses and use FoCal, how does the resolution below compare to your tests? I was a little disappointed in the 50L and 24L. I also really wish I kept the 35L long enough to test it against my new Sigma 35. ![]() I have this software and while it's amazing I will be completely honest. You cannot compare the sharpness results vs. other lens period. You notice the numbers get higher as your lenses get longer, thats because your getting closer. Put your 24L 6' away and see the numbers then put that lens 1' away and the numbers are alot higher. A7rIII | A7III | 12-24 F4 | 16-35 GM | 28-75 2.8 | 100-400 GM | 12mm 2.8 Fisheye | 35mm 2.8 | 85mm 1.8 | 35A | 85A | 200mm L F2 IS | MC-11
| Latest registered member is semonsters 1106 guests, 111 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
