kwsanders wrote:
I am considering the sale of my 50mm f/2.5 Compact Macro and an older 35-70mm f/3.5-4.5 to partiallly fund the purchase of a new macro lens that will give me full 1:1 magnification. The 50mm Compact Macro is only 1:2.
The Sigma is slightly more expensive than the Canon. Most of that is due to the 150mm vs 100mm, I would imagine. I do not know anything about the build quality of either lens.
Does anyone have any experience with either of these two lenses?
Well I have the 100mm Canon. This is a very well used lens. It makes a good telephoto lens also for general use.
At life size there is about 140mm of working distance from the front element. This is enough for most bugs, even dragonflies. The only problem bugs are butterflies. When my wife lets me I want to get some tubes to try on my 200mm for them (the EF 180mm macro is expensive and heavy).
The 150mm should give more working distance which is normally valuable but too much working distance can be a problem in undergrowth. Not shure what the weight differnce is but the less weight the better for handheld bug chasing.
Another point of you have a 20d but no macro flash you can get reasonable exposures with the internal flash with the 100mm (no hood), I don't know about the XT. The 150mm may be too long for this.
Consider how each focal length would fit into your system.
