Thread started 10 Feb 2013 (Sunday) 08:41
Mobo for i7 3770
ShotByTom
Gallery: 23 photos
Feb 10, 2013 08:41 |  #1
Can anyone suggest a motherboard under $200 for the i7 3770? I like the specs on this on this one: http://www.newegg.com …aspx?Item=N82E1​6813157295 (external link)
but I'm a little worried about the reports of DOA boards.
Any input will be greatly appreciated!
Gear
Website (external link)
RHChan84
Joined Apr 2011
Feb 10, 2013 08:48 |  #2
http://www.newegg.com …aspx?Item=N82E1​6813131790 (external link) for $134 with rebate.
ASUS, MSI, Gigabyte and Intel is the way to go for Mobo IMO. Those are the ones I trust.
That is just something I found but is there any specs you are looking for on a MoBo? USB3, PCI slots, ram slots, etc.
Canon (60D Gripped | 18-135mm f3.5-5.6 IS | 40mm f2.8 | 50mm f1.8 | 70-200 F4L IS| 430 EXII)
Tamron (17-50 f2.8 VC)
Feedback
Facebook (external link)
ShotByTom
Gallery: 23 photos
Feb 10, 2013 08:59 |  #3
I like the usb 3.0 on board so I can connect front panel usb 3.0 to the mobo. I also like a lot of sata 6gbs plugs, the AsRock has 4 and another 4 sata II ports. It has plenty of PCI slots but I doubt I will add a video card.
4 ram slots is a must! I plan to put in 32gb of ram. One thing I noticed abour your link is that it has the Z68 chipset, I think Z77 is the latest and fastest chipset.
Gear
RHChan84
Joined Apr 2011
Feb 10, 2013 09:10 |  #4
ShotByTom wrote in post #15593925 (external link)
Here are two more
http://www.newegg.com …aspx?Item=N82E1​6813131819 (external link)
http://www.newegg.com …aspx?Item=N82E1​6813131820 (external link)
Both with similar specs but more trustworthy brand IMO.
Feedback
ShotByTom
Gallery: 23 photos
Feb 10, 2013 09:15 |  #5
RHChan84 wrote in post #15593971 (external link)
Here are two more
Thank you! I'll take a good look at those!
Gear
RHChan84
Joined Apr 2011
Feb 10, 2013 09:19 |  #6
If I was building a new rig again, I would pick up either one of those since it has more then what I need.
I don't play games since I have a PS3 and the only thing I could see that uses any PCI slots would be video recorder from my PS3 to PC and out to my Tv or sound card. And I would probably only use 3 SATA sots.
Feedback
Tony-S
Feb 10, 2013 12:52 |  #7
I'd get this one, so you could put OS X Mountain Lion on it. ;)
http://www.newegg.com …10446076&PID=49​02415&SID= (external link)
"Raw" is not an acronym, abbreviation, nor a proper noun; thus, it should not be in capital letters.
Ainoko
Stupidest Question Award 2008
Feb 11, 2013 01:50 |  #8
ShotByTom wrote in post #15593871 (external link)
I just got that Mobo. Works great so far!
Full Gear List
https://photography-on-the.net …?p=4846834&post​count=1005
Colorblinded
Gallery: 18 photos
Feb 11, 2013 02:02 |  #9
My last couple mobos have been Asus and they've generally been good boards, no real complaints. This time I went with an ASRock as they too seem to have built a good reputation and I was happier overall with what it had versus the comparably priced Asus boards. Gigabyte are generally pretty good too.
The ASRock Z77 Extreme 4 (external link) is the model I'm running. It would be nice to have more space between the RAM and the CPU if you're using RAM with tall heatspreaders and a big cooler, as I am, but it all still fits just fine (I just had to take out the stick closest to the cooler during installation, then pop the stick back in).
You won't really go wrong with either.
The thing you have to realize with reviews on Newegg is that any recommended board or popular board is still going to have the buyers who got a dud. There may even be a lot of reports of the same failure but when you see something with hundreds of reviews and a rating of 4 or so "eggs" on average (which most of the popular and highly rated boards have) they're all generally going to be pretty solid. People nitpick about this or that but you're likely to have a good experience.
If you sort the Z77/1155 boards by best rating you have a few with 5 eggs but they only have a small number of reviews. The first board with a lot of reviews (640) and a fairly high score happens to be the ASRock Extreme 4 I mentioned and have myself. I'm running an i7-3770k and 32GB of DDR3 1866 RAM on it. Only had it running 24/7 for about a month and a half now but no hiccups yet!
Newegg reviews/scores, like any online retailer's, aren't perfect. You just kind of have to learn to interpret them.
Speaking of ASRock, I looked at the Extreme 6 (and similar boards from other manufs) but found no reason to spend the extra $$. The biggest difference to me was the inclusion of firewire which is nice, but I already have a PCI-Express Firewire 400/800 card from my old desktop that I moved over to the new one. Didn't make sense to get the board with onboard Firewire if it was only fw400. I've generally not found anything on the boards beyond about $140 that I've needed but some do come with some convenient features. I'm also not sure the Extreme 6 rates as highly as the 4, at that range the Asus may be the better choice. If you can live without the extras I'd get the ASRock Extreme 4 again without hesitation.
http://www.colorblinde​dphoto.com (external link)
http://www.thecolorbli​ndphotographer.com (external link)
ShotByTom
Gallery: 23 photos
Feb 11, 2013 12:37 |  #10
Thanks for the feedback and detailed information!
Gear
fotojennik
Joined Aug 2011
Feb 11, 2013 12:59 |  #11
I just built my PC two weeks ago with the i7-3770 and the ASRock Extreme4. Everything is running just fine :)
Pittsburgh Wedding Photographer (external link) | Flickr (external link) | Gear List
ShotByTom
Gallery: 23 photos
Feb 11, 2013 13:05 |  #12
fotojennik wrote in post #15598530 (external link)
Have you used the rapid start function? I like the idea of being able to instantly wake from sleep so I don't have to turn the pc off at night.
Gear
tickerguy
Joined Dec 2012
Feb 11, 2013 14:41 |  #13
I have an SSD on my desktop machine and it wakes from sleep as quickly as the monitors come up from sleep (~2 seconds or so.) How much faster is "instant"? :D
I like Intel and Gigabyte; have had mixed luck with Asus. Years ago I like them a lot, but in the last 4-5 years I had a DOA, which didn't make me very happy. If you want to build a hackintosh dual-boot Gigabyte seems to be the consensus.
Canon 7D & 5d3, EF-S 15-85, 24-105L, 70-200L f/4 IS, 100mm Macro/L, EF 50 f/1.4 and more
gotaudi
Feb 11, 2013 15:20 |  #14
Just built a 3770K with the ASUS Maximus V Gene for a CAD machine... Amazing board. I was going to go with the larger version but I really didnt need the excessive expansion since I was only going to use a raid card and a single GPU. Its solid as a rock and it has so many features. I also like the fact that I can use it later on for a file server when I need to upgrade later since the form factor is smaller.
fotojennik
Joined Aug 2011
Feb 13, 2013 13:55 |  #15
ShotByTom wrote in post #15598552 (external link)
No, I heard some negative feedback about it and never even tried it.
Plus, booting from an SSD is fast enough that I really don't feel the need to try it out.
3,080 views & 0 likes for this thread, 9 members have posted to it.
Mobo for i7 3770
1707 guests, 141 members online
