Thread started 10 Feb 2013 (Sunday) 09:28
Designated Caching Hard Drive
ShotByTom
Gallery: 23 photos
Feb 10, 2013 09:28 |  #1
Is it beneficial to have a designated caching hard drive, like THIS (external link) one, with an SSD system disk?
I plan to use a 240gb SSD drive for the OS, and was thinking of getting one of these to use with the main drive.
Gear
Website (external link)
vsg28
Joined Aug 2012
Feb 10, 2013 10:22 |  #2
No point having a caching disk for an SSD, it can't get any faster. It is only beneficial if you have a regular spinner HDD.
Canon 7D w/grip, Canon SX30 IS (modified for IR), Rokinon 14mm, Canon 24-105 L IS, Sigma 50mm, Canon 70-200 F/2.8 L IS II, Canon 100mm L IS, Kenko 1.4x Pro DG, Canon 2x II extender, Yongnuo YN-565EX, Induro CT414 with Induro BHL-3 and GHB-A
ShotByTom
Gallery: 23 photos
Feb 10, 2013 10:36 |  #3
vsg28 wrote in post #15594212 (external link)
Ok, thank you
Gear
tim
Light Bringer
Feb 10, 2013 21:12 |  #4
SSD as OS is nice, but isn't essential. Images on SSD helps a little. Cache, catalog, scratch, swap on SSD helps the most.
My setup is
C: OS, 60GB, Windows 64, takes 40GB with HEAPS of software
D: personal images 1TB
E: Commercial images 1TB
F: Cache/swap/scratch 120GB
M: Media 2TB
With a 2700K it goes pretty well :)
Albert ­ Nam
Joined May 2011
Feb 10, 2013 21:27 |  #5
If you have enough RAM, it shouldn't matter unless you're stitching together quite a few photos.
Gear
tim
Light Bringer
Feb 10, 2013 22:27 |  #6
SSD makes a HUGE difference to high volume image processing, if you put your cache, catalog, etc on there. Scratch probably won't help much as Albert says, but no harm either.
vsg28
Joined Aug 2012
Feb 11, 2013 07:05 |  #7
Are you guys even reading the OP's question?
tickerguy
Joined Dec 2012
Feb 11, 2013 14:44 |  #8
To the OP's question: No point to it if you have a SSD system disk.
Canon 7D & 5d3, EF-S 15-85, 24-105L, 70-200L f/4 IS, 100mm Macro/L, EF 50 f/1.4 and more
tim
Light Bringer
Feb 12, 2013 02:51 |  #9
vsg28 wrote in post #15597403 (external link)
OP's question wasn't very precise.
tkbslc
Feb 13, 2013 17:21 |  #10
ShotByTom wrote in post #15594034 (external link)
Can you clarify the question?
Were you looking at pairing the cache with the 240GB OS SSD drive or a second regular 7200RPM hard drive?
Taylor
EOS Rp | iPhone 11 Pro Max
ShotByTom
Gallery: 23 photos
Feb 13, 2013 19:27 |  #11
tkbslc wrote in post #15607090 (external link)
Yes, I was considering using a 32gb SSD drive as a cache drive along with an SSD drive as a main drive for OS. But now I understand the Cache drive is meant for regular spinning drives.
Gear
tkbslc
Feb 13, 2013 20:07 |  #12
ShotByTom wrote in post #15607513 (external link)
Yeah, reason being that you would just be moving data from one SSD to another SSD that is the same speed, so no improvement. If you are going to a spinning drive, then you get a huge random access speed boost.
Taylor
2,093 views & 0 likes for this thread, 6 members have posted to it.
1707 guests, 141 members online
