Thread started 10 Feb 2013 (Sunday) 13:54
Looking to a macro lens.......
mtsheron
Joined Feb 2013
Feb 10, 2013 13:54 |  #1
Will the Canon Ef-s 60 2.8 Macro Usm lens work great for me to do very very close shots for detail? In other works if I were within 1"-2" of my subject like a projectile from a gun would this lens work great with my T2i to pick up the rifling of the bullet?
Thank you-
I am just a spoke in a broken wheel.......
PacAce
Joined Feb 2003
Feb 10, 2013 14:03 |  #2
mtsheron wrote in post #15594979 (external link)
Thank you-
The closest focusing distance with that lens is about 7" (that's from film plane so it'll be a little less from the front of the lens itself) so you may need to use an extension tube or two to get even closer. But if you're trying to capture a flying bullet from an inch or two away, you'd better make damn sure your aim is very accurate lest you end up hitting the lens and shattering it to pieces. :shock:
...Leo
jaharris1001
Feb 10, 2013 14:09 |  #3
Thank you-
good luck with that one :rolleyes:
Jim
" I'm growin older,, but not up"
Jimmy Buffett
mtsheron
Joined Feb 2013
Feb 10, 2013 14:15 |  #4
Not trying to photograph a firing gun but rather the recovered projectile. Sorry, I should have clarified that.:lol:
PacAce
Joined Feb 2003
Feb 10, 2013 14:17 |  #5
mtsheron wrote in post #15595034 (external link)
In that case, it shouldn't be a problem. But you may need an extension tube to get really close to the bullet. :)
...Leo
Madweasel
Feb 10, 2013 15:15 |  #6
On a t2i (or any of the APS-C sensor bodies), at the closest focus of the EF-S60mm the physical field of view is the same as the size of the sensor, which is 22mmx15mm. So you can get all the way up to showing just 22mm of the bullet's length. I don't know much about bullet rifling, so hopefully you'll be able to judge whether that is close enough. My guess would be that it is.
Mark.
mtsheron
Joined Feb 2013
Feb 11, 2013 09:07 |  #7
Decided to get the R15 macro ring to reverse the 18-55 for now since I don't shoot alot of macro for now. For $6.40 shipped I will not be out alot if it is not as good. But from of the pics. I have seen taken doing the reversal method it is rather great for the price.
Thanks to all who responded.
watt100
Feb 11, 2013 10:31 |  #8
mtsheron wrote in post #15597749 (external link)
reversing rings work but sometimes they can get stuck on the mount - so proceed with caution !
1,156 views & 0 likes for this thread, 5 members have posted to it.
911 guests, 117 members online
