So, I finally bought a Sigma 30mm f/1.4 DC. But at the same time I have also gone from a 30D to a 7D which has thrown my idea of how sharp a pixel should be. There are just so many of them!
Obviously I do not expect the best performance wide open, but the shallow depth of field is a big part of the attraction, so it needs to be usable. I decided to take the lens with me to the local common as I went for a walk to try and learn the new body. Which is fantastic, incidentally, but oh, so many pixels.
I found a sign which I though would make a useful test that reflects a normal subject and situation, at least for me, and shot it in raw at f/1.4, f/2.0, f/2.8, and f/4.0.
This is a 100% view in DPP with no editing, so just a default sharpness of '3', and focus point displayed of the f/1.4 shot (handheld at 1/1000th, ISO 100, single AF point (one shot)):
And this is the same at f/4.0 (1/125th, obviously, and I had very slightly changed position):
The f/4.0 shot is a lot softer looking than I would have expected, but then there are all those pixels. Looking at it at a more normal size it looks fine, and will only be improved with normal local contrast and sharpening, which makes me think it is just the larger magnification at play. If so, then by comparison the f/1.4 performance does not seem that bad either.
I did also take the 50% view from DPP (I would have preferred 25% too, but there did not seem to be an option for anything between 50% and fit to screen). Here are links to the full set for each size:
100% views:
f/1.4
50% views:
f/1.4
Which all brings me to having to ask the hated question, do I have a good copy?
Thanks!
