Thread started 11 Feb 2013 (Monday) 08:58
Sling Strap And Backpack
Calicajun
Feb 11, 2013 08:58 |  #1
Been looking into getting a sling strap, seen lots of pictures and ads of people using one to carry their cameras. The only picture I haven't seen is someone using a sling strap and camera backpack at the same time. Can this be done and is so can it be done with comfort and still be convenient?
Thanks,
Craig
Remember, Stressed spelled backward is Desserts.:)
Suggestions welcome.
5DIII, EF 50 1.4, EF 40 f2.8, EF 24-105L IS , EF 70-200 f4L IS, 580EX ll
v35skyline
Feb 11, 2013 09:13 |  #2
As long as you get a sling that does not require the actual strap to move, but rather the camera (or its connections to the strap) glide on the strap.
X100s | X-Pro1 | X-T1 | XF 14 | XF 18 | XF 35 | XF 56 | XF 60 | XF 10-24
Gear List & Feedback
Calicajun
Feb 11, 2013 09:29 as a reply to  @ v35skyline's post |  #3
Okay, didn't know there were two types of sling strap designs on the market. Guess I should have looked closer at the ads. Then again I have used nothing but neck straps for over 30 years and change is not always easy.:o
v35skyline
Feb 11, 2013 09:35 |  #4
If you are in no rush, I'd recommend waiting for Luma Labs to release the Cinch mkii in the (hopefully) near future.
I currently use Op/Tech's sling strap because I use the Op/Tech system. This is an example of a sling strap where the camera glides on the strap. I keep the quick release uni-loops on my camera and am able to quickly switch between hand, neck, sling, and backpack straps. However, I plan to switch the the Luma Cinch when it is available.
leftnose
Joined May 2012
Feb 11, 2013 09:47 |  #5
v35skyline wrote in post #15597833 (external link)
I don't know about the MK II Cinch but I have the original version. The whole strap moves. The camera does not glide on the strap as you implied would be preferable for using with a backpack.
Snydremark
my very own Lightrules moment
Gallery: 57 photos
Feb 11, 2013 09:56 |  #6
Instead of a sling, I *highly* recommend the Capture Clip system from Peak Design for backpacking use. Fit the clip to the shoulder strap and the camera snaps in/out easily; can use the strap accessory as a safety strap and can convert over to use the shoulder strap with ease.
This system's held up to some some pretty hefty use for me; including a 25mph-ish snowmobile incident. Plus, the plate used to secure the camera can be had in Arca Swiss or RC2 compatible formats, so you can go straight from clip to tripod and back.
- Eric S.: My Birds/Wildlife (external link) (7D MkII/5D IV, Canon 10-22 f/3.5-4.5, Canon 24-105L f/4 IS, Canon 70-200L f/2.8 IS MkII, Canon 100-400L f/4.5-5.6 IS I/II)
Calicajun
Feb 11, 2013 10:14 as a reply to  @ Snydremark's post |  #7
Well I'm not in a big hurry, so taking my time and looking around more is not a problem. Became interested in this sling strap system after seeing one first hand at Best Buy. It was a Logic Case brand and the more I played with it (sales people not happy that I open the unit) the more it seemed like a nice way to carry a camera for long periods of time. Just wasn't sure if a sling strap would work with a backpack or how safe a $24.00 sling strap ans the $19.00 hand strap (the two worked together) would be for the camera. :confused:
Snydremark
Gallery: 57 photos
Feb 11, 2013 10:46 |  #8
Calicajun wrote in post #15597940 (external link)
Sling straps can be a fine way of carrying a camera for long periods; however, if you're doing more 'active' things, like hiking, it can be troublesome to have the camera swinging around like a pendulum. I would highly recommend going with one of the known manufacturers, too, such as Black Rapid, Sun Sniper, etc. Some, cheap, off the shelf brand from Best Buy would worry me as to the materials and workmanship that went into something that should be keeping several hundred dollars worth of camera gear off the ground.
I, also, suspect that you'll find having a strap and backpack on at the same time gets to be a 'mass management' nightmare.
Calicajun
Feb 11, 2013 10:59 |  #9
Snydremark wrote in post #15598049 (external link)
Wasn't planning on the cheap strap, it's just what made me interested in some type of sling system. As my neck doesn't seem to like having a camera around that much any more nowadays. Also like the idea of having a wrist strap on the camera. Just shot abut 200 pictures at my sons Karate meet and my hand was sore for about a hour after the meet.:o
jbrackjr
Joined Dec 2011
Feb 11, 2013 11:17 |  #10
I have had the Op/Tech's sling strap for about a year. It is inexpensive but very sturdy and convenient. Camera slides on strap smoothly. However, if your 6' 4" or taller you may need an extension as it will be to short. After using this, I got rid of all my neck straps.
Can't say how it will work with a backpack (don't have one).
Jim
Calicajun
Feb 11, 2013 11:51 |  #11
jbrackjr wrote in post #15598158 (external link)
Thanks, I'm only 5'10" so size shouldn't be a problem.:lol:
Lyndön
Feb 11, 2013 13:04 |  #12
Yes, it can be done. You just have to put the sling on either before the backpack, or before the right side backpack strap such that the sling sits on top of the left backpack strap. I've done the 2nd option a few times, since my BlackRapid strap has a pocket for my phone, extra memory cards, cash, etc. so I don't have to access the backpack for small things like that. It works really well if you're walking around the city, and it's ok if you're hiking on a mild/moderate trail. I use the front/rear bumpers to lock the camera as far back as possible so it's not sliding around while walking.
Calicajun
Feb 11, 2013 13:29 as a reply to  @ Lyndön's post |  #13
The you folks talk about the sling strap, the more I think we (wife and I) will take a drive to Samy's and Camulet in Hollywood, CA and check out these straps. I know, it sounds like a excuse just to drive down and shop at two big camera stores.:D
Thanks for the tips,
Craig
mafoo
Joined Dec 2011
Feb 11, 2013 14:27 |  #14
This is the one I have:
http://www.carryspeed.​com …s-slim-camera-sling-strap (external link)
I used to have the Black Rapid RS-5. The Black Rapid strap is a great strap, I just wanted something smaller.
I have used both with a backpack, and both work well.
I agree with Snydremark however, for a backpack solution. but if you go that route, also get a sling for when you don't have a backpack on. Your neck will thank you.
-Jeremy
5D Mk II | SL1 | 24-105 f4.0L IS | 70-200 f2.8L IS | S35 1.4 | 40 2.8 Pancake | Samyang 14 2.8 | 430EX II
Sirrith
Gallery: 50 photos
Joined Nov 2010
Feb 11, 2013 19:50 |  #15
Snydremark wrote in post #15597887 (external link)
Does the capture system work with L plates?
-Tom
5,168 views & 0 likes for this thread
Latest registered member is Schonher
721 guests, 251 members online
