Thread started 12 Feb 2013 (Tuesday) 11:12
How would you handle this venue?
Nathan
Can you repeat the question, please?
Gallery: 18 photos
Feb 12, 2013 11:12 |  #1
I'm 2nd photog on Saturday and just got some info about the reception venue. It's going to be at the Artists for Humanitie's function room (the Epicenter) in Boston. I asked the main photographer if she could ask about what the lighting situation will be.
If there are colored lights, I'm not sure how to go about it. Gel my flashheads, I suppose? I don't have the lighting equipment to light the room myself - besides, I'm the 2nd photog and not the main one.
I still want to do a good job. There doesn't look to be much to bounce off of, either. I have a Lumiquest Promax 80/20 system collecting dust in my closet. Should I go with that?
Here are photos of the hall: http://afhboston.org/e​picenter_pastevents.ph​p (external link)
Taking photos with a fancy camera does not make me a photographer.
www.nathantpham.com (external link) | Boston POTN Flickr (external link) |
5D3 x2 | 16-35L II | 50L | 85L II | 100L | 135L | 580 EX II x2
Thomas ­ Campbell
Joined Jun 2010
Feb 12, 2013 13:24 |  #2
Gaff tape an index card to a speed light. Instant bounced flash.
Houston Wedding Photographer (external link)
Houston Sports Photographer (external link)
Current Gear List
Nathan
Gallery: 18 photos
Feb 12, 2013 13:32 |  #3
I have the Lumiquest to bounce... unfortunately, that's still not a very large light source and not very directional.
I'm more worried about color.
rjcanon
Feb 12, 2013 13:35 |  #4
If I were shooting here I would not gel the flash, i would set WB for flash and use a decent defuser (or even the index card idea) and shoot with low enough shutter speeds to bring the colors in the background lighting up while freezing your foreground (and lighting it properly) with flash. I have had good results with this in the past, just watch for errant highlights if they are using moving lighting.
1DS MKIII, 1D MKIII, EOS R, 1D Classic, EOS 3, EOS 1V, 100-400L, 70-200 2.8L, 24-70 2.8L, 17-40 4L, 55mm 1.2, 100 2.8 macro L, 300 2.8L, Fuji X100s, Alien Bees + Pocket Wizards,
Lots of Mamiya 645 stuff...
smorter
Feb 12, 2013 16:49 |  #5
I would not use any diffuser or any index cards or stuff like that as it increases the harshness of bounced flash
Instead, keep rotating and tilting your flash towards surfaces that are close enough to bounce off - looking at the photos:
- the black curtains
- white poles
- white curtains
- white ceiling
- exposed cross section of the white panel section that forms the floor of the top level level
You'll need to set your ISO very high (e.g. ISO 1600+) etc. and use a large aperture prime, and those surfaces will be more than sufficient.
It'd be critical to keep rotating your flashhead so that you're bouncing off an appropriate surface.
Finally, if you're struggling for flash power, move your subjects under the lower ceiling sections as much as possible to maximise the power you have available
Wedding Photography Melbourneexternal link
Reviews: 85LII
gh ­ patriot
Feb 12, 2013 17:27 |  #6
smorter wrote in post #15603201 (external link)
- white poles
- white curtains
- white ceiling
This ^^^^^ with a 1/2 or full CTO on the flash. I do it all the time and works like a charm.
2 x 5D III | 40D | Rokinon 14 2.8 | 35L | 50[B]L | 85IIL | 100 L |135L | 300 f4L | | 24-70L | | 70-200 2.8L II | 2XL |
Jimconnerphoto
Feb 12, 2013 17:29 |  #7
What is your goal by putting gels on your lights? Are you attempting to neutralize the ambient?
Personally, when I have lighting like this I gel a 3/4 CTO. I don't want the lighting to be sterile. BUT, more importantly I want to match what my other shooters are doing. Since you are a second, check with the primary shooter and do what they do.
Wedding and Portraits www.jimconnerphoto.com (external link)
Commercial Work www.jamesdconner.com (external link)
gh ­ patriot
Feb 12, 2013 17:33 as a reply to  @ gh patriot's post |  #8
They had tons of purple accent lights all around for these. High ISO, large aperture and around 1/125th second to let in ambient light to capture the mood of the room but shooting about 1 1/2 to 2 stops under ambient and then bringing it back up with combinations of on and off camera flash.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/02/2/LQ_636761.jpg
Image hosted by forum (636761) © gh patriot [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/02/2/LQ_636762.jpg
Image hosted by forum (636762) © gh patriot [SHARE LINK]
gh ­ patriot
Feb 12, 2013 17:36 as a reply to  @ gh patriot's post |  #9
One more with one camera bounced of ceiling for fill and two off camera cross lit. 1/2 or 3/4 CTO on all
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/02/2/LQ_636763.jpg
Image hosted by forum (636763) © gh patriot [SHARE LINK]
Nathan
Gallery: 18 photos
Feb 12, 2013 21:03 |  #10
My goal is simply to make sure the subjects look natural, but I hope to maintain ambiance through ambient.
Thanks everyone. A few questions:
  • You can bounce off of black curtains?
  • What happens when you bounce off a white wall that's been lit with purple lights? Does the bounced light carry with it some of the purple?
The CTO shots above look good! I hope I could do similarly given my set up of lenses. The largest aperture I have is on my Sigma.
NewHorizonPhoto
Joined Jul 2011
Feb 13, 2013 01:33 |  #11
Nathan wrote in post #15603999 (external link)
The short answer is: No. The bounced light is the bounced light, and the purple light is the purple light.
If you get a purple color cast on your subjects from a wall lit with purple lighting it is because you are allowing that ambient light in your photo. One way to avoid this is to meter your ambient exposure 1-2 stops underexposed. Then let the flash take care of the rest. When your bounced flash hits that white wall lit with purple lights it will vastly overpower the ambient light and will reflect back onto your subjects with the white flash light.
Remember that when using a flash there are actually 2 different exposures happening at the same time: Ambient exposure and Flash exposure. How you mix these two together determines your overall exposure. For most people, the flash exposure is handled by the camera by using TTL mode. You tell the camera how you want ambient, and it will adjust the flash power accordingly. You can get a decent exposure in a dark venue by using only natural ambient light and no flash. Or, if you had enough juice, you could take a picture outside in direct sun during the summer solstice using a flash and end up with an entirely black background. Just don't forget to remind your subject that the blindness is only temporary.
Hope this helps.
samsen
Feb 13, 2013 02:12 |  #12
gh patriot wrote in post #15603336 (external link)
Strategy worked well.
When there is a choice of color, ambient color is room is what the Bride has chosen and accentuation of that in your images makes the important decision maker of the night, quit happy.
Weak retaliates,
Strong Forgives,
Intelligent Ignores!
Samsen
Picture editing OK
2,332 views & 0 likes for this thread, 8 members have posted to it.
1458 guests, 127 members online
