Thread started 12 Feb 2013 (Tuesday) 20:27
New Camera Recommendation(s)
tab10
Joined Feb 2013
Feb 12, 2013 20:27 |  #1
Good evening. New member here.
A google search brought me to this forum and I have spent the last few days checking out the forums. Great place ya'll have here.
I am very much amateur, novice photographer. I would be interested though in becoming more serious about it as hobby.
My interests mainly would be outdoor, landscape photography, but I would use it as a general walk around camera as well. Also I'm interested in storm photos, so I am eyeing a Sigma 10-20, or used Canon 10-22.
I am torn on what camera to get though. At first I thought I was pretty set on getting the T4i, but then I started looking at the 60D. I am having a difficult time deciding between the two. Which of the two would do you think would better suit my needs? Any other camera(s) I should consider?
Thanks for your time!
maverick75
Joined May 2012
Feb 12, 2013 20:34 |  #2
Its a tough choice between those two. 60D has a batter body which makes a huge difference, T4i has the advantage of newer technology. Either will suffice, I'd go with the 60D though.
procharged91stang
Joined Dec 2011
Feb 12, 2013 20:45 as a reply to  @ maverick75's post |  #3
Get the 60d. Better battery life, faster shutter speed, top LCD, better controls. I had the 60d before I purchased my 5d mk II and had no complaints.
SL1 | 18-55 EF-S IS STM | 55-250 | EOS-M | EF-M 22 STM | EF-M 11-22 IS STM | EF-M 18-55 IS STM
tab10
Joined Feb 2013
Feb 13, 2013 05:34 |  #4
I am leaning towards the 60D at this point. But I am going to keep looking things over.
I pretty much know I will either get a canon 10-22 or sigma 10-20, but what would y'all recommend for an everyday general purpose lens.
Phoenixkh
a mere speck
Gallery: 67 photos
Joined May 2011
Feb 13, 2013 06:38 |  #5
I ended up with the 60D and am pleased with it. For an every day lens, you'll probably get at least two recommendations: the Canon EF-S 17-55mm f/2.8 IS and the Canon EF-S 15-85mm f/3.5-5.6 IS.
I have no personal experience with the 17-55 but many people here love it. You can see their reasons and their results here: https://photography-on-the.net …ighlight=Canon+​EF-s+17-55
I chose the 15-85 even thought it's a slower lens because we live in Florida and I use my 60D outside for the most part. I have a flash gun for indoor shots. Here are some examples of the 15-85:https://photography-on-the.net/forum/showthre​ad.php?t=760140
Kim (the male variety) Canon 1DX2 | 1D IV | 16-35 f/4 IS | 24-105 f/4 IS | 100L IS macro | 70-200mm f/2.8L IS II | 100-400Lii | 50 f/1.8 STM | Canon 1.4X III
RRS tripod and monopod | 580EXII | Cinch 1 & Loop 3 Special Edition | Editing Encouraged
Keyan
Joined Mar 2011
Feb 13, 2013 07:03 |  #6
The 17-55 is super capable, but yes it is expensive. Depending on your need you may find the 15-85, with it's wider range, to be a better fit. Here are samples I have taken with the 17-55:
http://www.flickr.com …6/sets/72157632​375444982/ (external link)
Personally I love the 60D. Part of it depends on what your main purpose of the camera is going to be - photos, or do you need a good blend of video? The T4i is the only Canon that does autofocus during video, even though it can be somewhat limited (it has a tendency to wait until the subject moves out of the focal plane before then trying to focus again)
If you are more into photography and are OK with manually focusing during video the 60D is the better camera. The T4i does a little more in-camera noise reduction due to the Digic 5, however RAW performance is basically the same. The 60D really shines with its ergonomics, faster shutter, pentaprism viewfinder, level, larger battery, 1/3 stop auto ISO, top LCD, and a few more. I use mine as a photography tool with occasional video (which looks great), so I am still glad I bought the 60D. Paired with the two heavier lenses I own, the larger and somewhat heavier body provides a more stable and balanced kit.
Cameras: 7D2, S100
Lenses: 17-55 f/2.8 IS USM, 18-135 STM, 24-70 f/4L IS USM, 50 f/1.4 USM,70-300L IS USM
Other Stuff: 430 EX II, Luma Labs Loop 3, CamRanger
amfoto1
Feb 13, 2013 10:01 |  #7
tab10 wrote in post #15604868 (external link)
I'd always recommend give lenses your first consideration... perhaps buying a little less camera in order to afford the lenses you need or want, if necessary. Quality lenses will always make more difference in your images, than the camera they are used upon. Lenses also tend to be a longer term purchase.
The Canon EF-S 10-22 is a very good lens. It has aoubt the best overall image quality of any of the ultrawides... but it also is the most expensive.
I'd rank the Tokina 11-16 and 12-24 second to the Canon... the 12-24 costs a lot less, has almost as nice image quality and is just slightly less flare resistant than the Canon. The 11-16 is less money than the Canon too, though more expensive than the 12-24... It's the only f2.8 ultrawide, quite sharp, but has more propensity to flare and only a narrow range of focal lengths. An interesting Sigma is the 8-16mm... the widest lens available for crop cameras, short of a fisheye. It is one of the more expensive and has pretty strong wide angle distortion effects, but goes where few other lenses do.
The Canon EF-S 17-55/2.8 is a super lens... top choice, but rather pricey. A cheaper alternative is the Tamron non-VC 17-50/2.8. the But, again, to get f2.8 you end up with a relatively narrow range of focal lengths. There's also a Sigma 17-50/2.8 OS, which has a lot of fans. If you get one of these fast standard zooms in the 17-whatever range, it might match up well with an 11-16 or 8-16mm ultrawide.
But 17-50 or 17-55 doesn't give you very much reach... 55mm is only "short telephoto". If you want more telephoto, you might want to add an EF-S 55-250 (cheapest), EF 70-300 (several to choose among) or EF 70-200 (also several choices).
An alternative I often recommend, especially whenever someone is buying an ultrawide anyway, the Canon EF 28-135 IS USM can be found used for around $200 and makes a very nice walkaround lens. It's a great value on the used market because there are so many of them... That's because a lot have been sold in kit with 40D and 50D especially. But it's not a typical "kit" lens in build, performance and mage quality. In those respects, it closely rivals the far more expensive 24-105L (the L-series is better built/sealed). The 24-105L is a premium alternative... but at about 4X or 5X the cost. These lenses are also EF... compatible with full frame. They'll work fine on a crop camera, but also can be used on FF if that's ever needed. Most of the other lenses discussed here are EF-S or third party "crop only" that will be fine on T4i/650D or 60D, but not on any of the full frame camera models.
Canon 18-135 IS is a step-up kit lens... up from the 18-55, it lacks USM, tho the latest version has STM. It and the more expensive 15-85 IS USM might be good choices if wanting to work with only a single lens. The 15-85 is the widest of the standard or walkaround zooms and there is noticeable difference between 15mm and 18mm.... a few millimeters make a big difference between wide angle lenses.
But if buying an UWA anyway, I'd go with either the 17-55 (if f2.8 is needed) or 28-135, depending upon which UWA is chosen.
So you might end up with...
One lens:
15-85 or 18-135.
Two lenses:
10-22 or 12-24 paired up with 28-135 or 24-105L.
Three lenses:
11-16 or 8-16 + 18-135, 15-85 or 17-55/17-50 + 55-250, 70-300 or 70-200.
To me, 60D is a bit more desirable camera than T4i, for the higher shutter speed, frame rate and flash sync. But the two have fairly equal AF performance and the latter has some enhancements specifically for video and to make full use of the new STM lenses. Size, shape, ergonomics and controls are a little different... so it's best to go compare in a store, if at all possible.
base_nine
Joined Aug 2012
Feb 13, 2013 11:29 |  #8
You really need to go and handle both cameras. Feel where the buttons and dials fall when your fingers are wrapped around the grip.
I chose the 60D - I have long fingers and the 60D felt more natural in my hands. And I liked the extra weight - it feels more stable with bigger lenses.
My wife does not like the 60D. While she will use it, she feels it is too big and hefty for her hands. If she was the primary user, we would have bought the T4i (650D) and been equally happy with it. My wife prefers using my old Digital Rebel (300D) because it is more comfortable for her.
Canon 60D with EF-S 18-135mm f/3.5-5.6 IS STM
Canon SX50 (wife's camera)
Canon EF 50mm II f/1.8, Tamron 17-50 f/2.8, Tamron 70-300 VC, Opteka 500mm f/8 mirror lens, Speedlite 430EX II
Long time enthusiast - been photographing since my teens in the 80's.
binlu12
Joined Jan 2013
Feb 13, 2013 12:48 |  #9
I totally agree with other people's recommendation of 60D. I started in 2011 with a T2i, then move to T3i. Then I tried 30D and 40D and liked the feel so much better than Txi's so that I ended up with a 60D. It works great so far.
6D, 7DII, 1DII, 24-105mm f/4L IS USM, 70-200mm F/4L IS USM, 15-85 IS USM, Sigma 50mm f/1.4 DG HSM Art, 600EX-RT
Feedback #3
Feedback #2
Feedback #1
Ilovetheleafs
Raising uninteresting to new levels
Gallery: 20 photos
Joined Jul 2011
Feb 13, 2013 17:06 |  #10
I'd say go with whatever body is cheaper, and then add an additional lens on top of that. As just having a 10 - 20 / 22 will be very limiting.
Canon Rebel XS gripped, Canon 18 - 55mm, Sigma 18 - 200mm f3.5 - f6.3 DC OS HSM,Sigma 50mm f1.4 Olympus TG-810 Tough, LowePro Classified 160AW, Canon 430EX II Flash, Kata E-702
1,791 views & 0 likes for this thread, 9 members have posted to it.
1186 guests, 130 members online
