Hi
i'm just reading focal Fully Automated Camera Calibration
http://www.reikan.co.uk/focalweb/![]()
it's in english and i 'm tring to translate it
should i take shots of the monitor?
does it work?
do you use it?
thanks!
mantra Goldmember 1,617 posts Joined Nov 2006 Location: Italy, Rome More info | Feb 13, 2013 12:22 | #1 Hi canon 5d markII,24L & 24ts , 35L ,17-40L,24-70L,70-200 2.8ISL,50 1.4,85 1.4 , canon eos 3 ,eos 5 ,t90 , ae program and some very sweet fd lenses
Feb 13, 2013 14:06 | #2 Have you read this thread? Flickr
Trvlr323 Goldmember 3,318 posts Likes: 1091 Joined Apr 2007 More info | I've used the software. I found that it works...and it doesn't. I'll offer my expereince with all due respect to those who swear by it. Sometimes not taking a photograph can be as problematic as taking one. - Alex Webb
marcosv Senior Member 775 posts Joined Oct 2009 Location: San Jose, CA More info | Feb 13, 2013 16:25 | #4 As I've mentioned in the other thread, I also wasn't that impressed with the software due to repeatability issues and lack of feedback on whether my lens was front or rear focusing. The software could give me the impression that it nailed the adjustment, but, when I test the adjustment, I'm not that happy with it. EOS-M | 40D | 5DII | 5DIII | EF-M 22 | EF-M 18-55 | 10-22 | 17-55 | 17-40L | 24-70L mk II | 24-105L | 70-200/2.8L IS mk II| 35L | 85L II |35/2 | 40/2.8 pancake | 50/1.8 | 50/1.4 | 100/2 | Rokinon 14/2.8 | 90 EX | 270 EX II | 580 EXII | 600 EX-RT
Feb 14, 2013 05:14 | #5 No. You need to print the target that Reikan include. Print it on A4 paper, with an inkjet if you can, but a laser printer will also work. mantra wrote in post #15606018 does it work? Yes. You do need a lot of light. And the light must be consistent - it must not vary a lot. But then it works very well indeed. mantra wrote in post #15606018 do you use it? Oh yes! I have used it for about 20 lenses on my two cameras and another 6 lenses on a friend's camera. mantra wrote in post #15606018 thanks! You are most welcome. Frank Hollis - Retired mass spectroscopist
bobbyz Cream of the Crop 20,506 posts Likes: 3479 Joined Nov 2007 Location: Bay Area, CA More info | Feb 14, 2013 08:49 | #6 Used it couple of times with my 5dmk3 and 35L, 135L, and 85mmf 1.8. So many times it will tell me target not found when doing the adjustment when target was successfully acquired and nothing moved. Test done on a nice tripod in a empty parking lot so no wood floor issues IMHO. Overall it was better than doing anything manual and tests seemed repeatable if done in good light. Fuji XT-1, 18-55mm
05Xrunner Goldmember, Flipflopper. More info | Feb 14, 2013 09:30 | #7 bobbyz wrote in post #15609122 Used it couple of times with my 5dmk3 and 35L, 135L, and 85mmf 1.8. So many times it will tell me target not found when doing the adjustment when target was successfully acquired and nothing moved. Test done on a nice tripod in a empty parking lot so no wood floor issues IMHO. Overall it was better than doing anything manual and tests seemed repeatable if done in good light. Wish it had auto support for 5dmk3 but that is more a canon issue of changing the api. Same exact problem I had. Everything was setup and image validation. Half way through says cannot find target. Reiken tried to blame me for the issue. But they are refunding me My gear
Feb 14, 2013 13:38 | #8 bobbyz wrote in post #15609122 Used it couple of times with my 5dmk3 and 35L, 135L, and 85mmf 1.8. So many times it will tell me target not found when doing the adjustment when target was successfully acquired and nothing moved. Test done on a nice tripod in a empty parking lot so no wood floor issues IMHO. Overall it was better than doing anything manual and tests seemed repeatable if done in good light. Wish it had auto support for 5dmk3 but that is more a canon issue of changing the api. I didn't get along with it at all sadly - the two cameras I tried it on were the 1DIII and 5DIII - neither are fully compatible and neither worked well for me.
Domino1999 wrote in post #15606360 Have you read this thread? https://photography-on-the.net …/showthread.php?t=1272615 i swear nqjudo wrote in post #15606556 I've used the software. I found that it works...and it doesn't. I'll offer my expereince with all due respect to those who swear by it. I used the software and like most I found that my focus was improved hence my initial reaction wasn't unlike many people who rave about the software. I thought it was great, wondered how I got along without it and was even a little upset that Canon didn't provide this performance out of the box. Yes, the software appeared to give better post-calibration results when verified in the sterile conditions in which the calibration was performed but over time I found that it was six of one and half a dozen of the other. AF systems perform differently depending on a lot of factors. Lighting, focal distance and on and on. I found that using my lenses micro-adjusted or not provided the same amount of keepers, non-keepers, super sharp focused and softer images taken over a period of time. My assumption is that micro-adjusting vs. non-micro adjusting provides equal performance but the peak performance becomes apparent under different conditions. So since then my approach has been if my results aren't going to be improved why bother with the expense and time? thanks for the feedbacks! marcosv wrote in post #15606890 As I've mentioned in the other thread, I also wasn't that impressed with the software due to repeatability issues and lack of feedback on whether my lens was front or rear focusing. The software could give me the impression that it nailed the adjustment, but, when I test the adjustment, I'm not that happy with it. In the end, I prefer using Lens Align, despite the cost and the flimsy material that makes me hesitant from taking it apart for travel. But, you should try FoCal for yourself first. If it works for you, it's really portable. thank to you tooo canon 5d markII,24L & 24ts , 35L ,17-40L,24-70L,70-200 2.8ISL,50 1.4,85 1.4 , canon eos 3 ,eos 5 ,t90 , ae program and some very sweet fd lenses
Feb 16, 2013 00:40 | #10 hollis_f wrote in post #15608773 Before FoCal I only did 4 lenses on one camera because it took too much time. But FoCal is so quick and easy that it was OK to do all my lenses. You are most welcome. thanks a lot! really canon 5d markII,24L & 24ts , 35L ,17-40L,24-70L,70-200 2.8ISL,50 1.4,85 1.4 , canon eos 3 ,eos 5 ,t90 , ae program and some very sweet fd lenses
CanonBob Goldmember 2,063 posts Likes: 52 Joined May 2007 Location: Poitou-Charentes, France More info | Feb 16, 2013 02:39 | #11 mantra wrote in post #15615356 ......so i have to shoot with a great ammount of light a paper (chart) , cf - PC and load the images in the program and it should analyze them ? No, you connect the camera to your PC via the USB cable and the software takes the shots, performs the analysis and modifies the MA value to the best figure and then generates a report for you. 1Dx2 (2), 5DSR, 1Ds3, 1D4, 5D2(590nm), 5D2(720nm) EF600 EF400 EF300-II EF300 EF200 EF200-II EF180L EF135L EF100 EF85-II EF50L TS-E17/4 TS-E24L-II TS-E45 TS-E90 MP-E65 EF70-200-II EF24-70/2.8-II EF16-35/4 EF8-15/4 EF11-24/4 Zeiss 15/2.8 21/2.8 25/2 28/2 35/1.4 35/2 50/2 85/1.4 100/2 135/2 T/C's L-SC & a WIFE!
Feb 16, 2013 02:44 | #12 I used it. Got great result. I would recommend it.
Feb 18, 2013 01:25 | #13 Canon Bob wrote in post #15615499 No, you connect the camera to your PC via the USB cable and the software takes the shots, performs the analysis and modifies the MA value to the best figure and then generates a report for you. Bob kouasupra wrote in post #15615503 I used it. Got great result. I would recommend it. thanks canon 5d markII,24L & 24ts , 35L ,17-40L,24-70L,70-200 2.8ISL,50 1.4,85 1.4 , canon eos 3 ,eos 5 ,t90 , ae program and some very sweet fd lenses
Feb 18, 2013 02:32 | #14 mantra wrote in post #15622403 how can i know if the camera is 100% perpendicular to the chart ? i guess it's important It's not important. As long as it's near perpendicular it'll be OK. I just eyeball it. Again, I estimate somewhere between 20 and 50x the focal length. So, for a 100mm lens I put the target somewhere about 2 to 5m away. Frank Hollis - Retired mass spectroscopist
Feb 18, 2013 04:42 | #15 hollis_f wrote in post #15622471 It's not important. As long as it's near perpendicular it'll be OK. I just eyeball it. Again, I estimate somewhere between 20 and 50x the focal length. So, for a 100mm lens I put the target somewhere about 2 to 5m away.
| Latest registered member is semonsters 1053 guests, 103 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
