I do very well understand the "load capacity" for the ball head that you put on as it will actually need to hold the gear.
However I am bit confused as to how does the same work with the legs. (Especially those w/o center column)
Many times you see the recommendations to hand you camera bag/sand bag or some such thing to the bottom of the center column to stabilize the tripod. Which also means more the weight (to a limited extent) you put on tripod, the stable it is.
Then why the legs have to be rated say 15 lbs load capacity.
If I put 20 lbs of gear on it, wouldn't it be more stable?
In which case should your legs be rated 2 or 3 times the gear you are going to put on it?
Again this is when center column is not in picture as it could be the weak link in the whole equation..
