Thread started 15 Feb 2013 (Friday) 11:55
Sync issues with Einstein 640W strobes..
5W0L3
Joined Mar 2012
Feb 15, 2013 11:55 |  #1
Ive been having this issue from last couple of events where I started using einsteins as off camera flashes.. basically what happens is:
about an hour or so into the event one of the einstein starts flashing marginally before the other one (i.e. they both go out of sync)... once I walk upto them and turn them off and back on.. they get back in sync again for another hour or so (roughly)... has anyone else had this issue with their einsteins?.. is there a fix?
Im asking this because I usually place them both directly opposite to each other facing the dance floor... so if one goes off even milliseconds before the other, I get some shadows on one side of the face of subjects which don't look flattering.
Manav
5D III x 2 (gripped) | 35L | 85L II | 100L | 24-70mm IIL | 70-200mm IIL | Some strobes & some speedlights.
Richard ­ Cranium
Joined Feb 2013
Feb 15, 2013 12:08 |  #2
What triggers are you using? Are both of your strobes using a trigger? Or are you triggering one, and relying upon the optical trigger on the other? It sounds more like one of the strobes simply isn't firing, rather than the strobes firing at different times.
SMP_Homer
Gallery: 29 photos
Feb 15, 2013 12:18 |  #3
swap trigger between those 2, and see if issue stays or follows trigger
EOS R6’ / 1D X / 1D IV (and the wife has a T4i)
Sig35A, Sig50A, Sig85A, Sig14-24A, Sig24-105A, Sig70-200S, Sig150-600C
100-400L, 100L, 100/2, 300 2.8L, 1.4x II / 2x II
600EX-II X3, 430EX-III X3
5W0L3
Joined Mar 2012
Feb 15, 2013 12:37 |  #4
Using 2xCST on my cameras (2 bodies).. and using the CSRXB or whatever they are called on the strobes.. the ones which have pins at the bottom and you plug them on top of the strobes.
Slave mode is off
Manav
Turning
Feb 15, 2013 12:48 as a reply to  @ 5W0L3's post |  #5
It doesn't sound like your problem, but I sure have had weird problems when batteries were a bit low in the transmitter.
Seems fussy that way and so far when I put in newer batteries the weirdness went away. Kind of hate it as when I measure the voltage on the "old" batteries it's not usually that bad.
I agree with swapping receivers though and see what happens.
dmward
Gallery: 29 photos
Feb 15, 2013 13:03 |  #6
Asking this on the Buff tech forum, or by calling Buff customer service would probably get it resolved a lot faster than posting here.
I use Einsteins with the same receivers and triggers and have never had that problem. I suspect its something in one of the lights. Do you have them marked so you can tell if its always the same light?
Do you have the receivers marked so you can tell if the problem moves with the receiver?
Do you have the triggers marked so you can tell if it moves with the trigger?
Those are all standard trouble shooting techniques.
xburrows
Feb 15, 2013 16:21 |  #7
Turning wrote in post #15613452 (external link)
I've experienced the weirdness with a low battery in the transmitter.
dmward wrote in post #15613496 (external link)
Yep, call the folks at PCB. Great customer service.
Turning
Feb 16, 2013 11:52 |  #8
Richard Cranium wrote in post #15613326 (external link)
Thinking about it later, I agree it sounds more like a light not firing.
Or it would take alot more difference in timing than milliseconds.
Did you ever figure it out?
2,356 views & 0 likes for this thread, 6 members have posted to it.
1059 guests, 104 members online
