Looking to pick up a good but rather budgeted distance lens. I have a canon rebel. I am very much into the wild life shot and being a distance away will help get better shots.
Feb 16, 2013 00:16 | #1 Looking to pick up a good but rather budgeted distance lens. I have a canon rebel. I am very much into the wild life shot and being a distance away will help get better shots. 1D X MII
steveh74 Member 52 posts Joined Nov 2012 Location: Italy More info | Feb 16, 2013 00:26 | #2 Maybe try the Sigma 70-300mm f/4-5.6 DG Macro Tele Zoom Lens. I had one when I first started out an was looking for a budget lens. Took many great shots with it before I upgraded. CANON: EOS 60D/ IXUS 100 IS
Feb 16, 2013 01:42 | #3 kcrunchone wrote in post #15615307 Looking to pick up a good but rather budgeted distance lens. What do you consider "budgeted"? For some that might be $100 for others it might be $1000.......
TweakMDS Goldmember 2,242 posts Likes: 1 Joined Nov 2008 Location: Netherlands More info | Feb 16, 2013 05:26 | #4 ^^^ this. Some of my lenses focus beyond infinity...!
T2i4me Goldmember 2,906 posts Likes: 7 Joined Jun 2011 Location: Surf City, CA More info | Feb 16, 2013 09:39 | #5 Best bang for the buck is the 55-250, it has IS and it's quite sharp for the price. It's also very light weight and small so it's easy to carry, this lens is often supplied as a "kit lens" for the Rebels so used ones are easy to find. If you can stretch your budget the 70-200 L F4 (non-IS) can be found used for $500 or less and is tack sharp. Check out the lens forums for both of these lenses and you can see the quality of photos they are capable of. -- Eric --
mikepro Hatchling 5 posts Likes: 6 Joined Jul 2012 More info | Feb 16, 2013 09:43 | #6 The Canon 55-250 is surprisingly good, and very affordable.
Cgb628 Member 152 posts Joined Nov 2012 Location: North Carolina More info | Feb 16, 2013 09:57 | #7 50-250. 1DX - 1D3
Apricane Shooting the breeze More info | Feb 16, 2013 10:33 | #9 I disagree, 55-250 doesn't have AF that is, in most circumstances, quick or accurate enough for wildlife. I'd look for USM or equivalent in a wildlife lens. Apricane flickr
Feb 16, 2013 10:37 | #10 Apricane wrote in post #15616217 I disagree, 55-250 doesn't have AF that is, in most circumstances, quick or accurate enough for wildlife. I'd look for USM or equivalent in a wildlife lens. I don't entirely agree here. It certainly isn't as fast as the best but it isn't to shabby. It is as fast as the cheaper canon usm models such as 75-300 in my experience flickr
casaaviocar Senior Member 887 posts Joined Jun 2006 More info | Feb 16, 2013 10:55 | #11 Apricane wrote in post #15616217 I disagree, 55-250 doesn't have AF that is, in most circumstances, quick or accurate enough for wildlife. I'd look for USM or equivalent in a wildlife lens. You do realize that all wildlife photography before 1983 was done with manual focus? Rule books are paper they will not cushion a sudden meeting of stone and metal -ekg-
DreDaze happy with myself for not saying anything stupid More info | Feb 16, 2013 14:44 | #12 Apricane wrote in post #15616217 I disagree, 55-250 doesn't have AF that is, in most circumstances, quick or accurate enough for wildlife. I'd look for USM or equivalent in a wildlife lens. it's definitely fast enough for wildlife...might not be the best for small BIF, but it'll work better than anything else near it's price point... Andre or Dre
Apricane Shooting the breeze More info | Feb 16, 2013 15:16 | #13 casaaviocar wrote in post #15616274 You do realize that all wildlife photography before 1983 was done with manual focus? I don't see how that's relevant; it is certainly possible to do so, but it's still not a reason to still recommend doing it. My first wildlife lens was the 55-250, and I'm quite happy I was able to afford a good upgrade. Apricane flickr
Feb 16, 2013 15:35 | #14 Apricane wrote in post #15616217 I disagree, 55-250 doesn't have AF that is, in most circumstances, quick or accurate enough for wildlife. I'd look for USM or equivalent in a wildlife lens. I have 635 shots, all about the same level of sharpness or better (H shoots pretty fast at 5 fps)... tossed about 20 because I wasn't adept enough to put the object where the 60D could see it. Gerry
Apricane Shooting the breeze More info | Feb 16, 2013 15:45 | #15 MakisM1 wrote in post #15617079 I have 635 shots, all about the same level of sharpness or better (H shoots pretty fast at 5 fps)... tossed about 20 because I wasn't adept enough to put the object where the 60D could see it. It is the 18-200 and it doesn't say USM anywhere... ![]() See my post just above yours. Apricane flickr
| Latest registered member is semonsters 920 guests, 117 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
