Thread started 17 Feb 2013 (Sunday) 01:27
24-105 IS Blured when stopped down
Don_T70
Joined Jan 2013
Feb 17, 2013 01:27 |  #1
After goggling the 24-105 I ran across a post about it being blurred when it was used at slow shutter speeds. The tests were done at 1/5 shutter and F4. Another shot was taken at 1/5 and F5.6 and there is a noticeable difference. It looks like it is a problem with newer lenses. My 24-105 was delivered a few weeks ago. Here are my results. It should be obvious which image was shot at f4 and which one was shot at f5.6. Both shots are with IS turned ON. From what I read Canon will fix this issue. I am not happy about having to send a 2 week lens back for repair, but it will give me some time to play with a few others.
Donald in Long Beach CA
EDIT - Apologies if this has been addressed. I searched but didn't find anything.
Canon 6D. 24-105mm - 40mm Pancake - 20-35mm 2.8- 85mm 1.8 - 100-400L - Nifty 50
minh2pac
Feb 17, 2013 02:06 |  #2
Your shutter speed is WAY too slow
Kevin
5d3, 7d, xe-1, om-d
mike_d
Feb 17, 2013 02:10 |  #3
Its going to be tough to get sharp shots at that shutter speed. If you take 10 shots at each aperture, are the f/4 shots consistently better than the f/5.6 shots?
tkbslc
Feb 17, 2013 02:24 |  #4
I think you need a bigger sample size.
What focal length were these taken at? 1/5 is borderline even with IS and probably only going to be consistent at the wide end of the range.
Taylor
60D | ELPH 330 | iPhone 5s
jabtas
Gallery: 194 photos
Joined Jan 2005
Feb 17, 2013 02:32 as a reply to  @ tkbslc's post |  #5
Tripod shot?
if so, turn the IS off
Tim
Some Canon stuff, some Sigma stuff and yet more Canon stuff
My Gallery - http://www.pbase.com/j​abtas (external link)
Crafty
Feb 17, 2013 02:37 |  #6
I vote for shake.
Repeat the test with IS off and the camera on a tripod.
tkbslc
Feb 17, 2013 02:39 |  #7
I think he was trying to test the IS, though.
Taylor
Stickman
Feb 17, 2013 12:47 |  #8
Fix what issue? You are using to low of a shutter speed, IS doesn't stand for Independant Sorcery.
Stick
http://www.flickr.com/​photos/stickgunner/ (external link)
dochollidayda
Gallery: 40 photos
Joined Aug 2012
Feb 17, 2013 12:51 as a reply to  @ Stickman's post |  #9
Read the OP twice, I don't understand the recognized problem OP speaks of. At 1/5 seconds it is relatively difficult to take sharp photos. I mean IS helps but its not magic.
flickr (external link) | 500px (external link) | Instagram (external link)
mike_d
Feb 17, 2013 14:11 |  #10
dochollidayda wrote in post #15620069 (external link)
But at the same shutter speed, aperture shouldn't affect the shake-induced blurriness. It sounds like the thread starter thinks it does in his case. That's why I wanted him to take a bunch of shots at each aperture (with the same SS) and see if there's any difference in the keeper rate between the two apertures. I doubt there's going to be too many keepers at 1/5' though. Maybe 1 in 5 would be acceptable for low res web use.
wombatHorror
Feb 17, 2013 18:11 |  #11
I read about this on another forum. It was proven to be a real defect. The IS goes wonky if you change the shooting aperture away from wide open, as crazy as that sounds. Some batches had some electronics messed up. A couple guys sent their body and 24-105 in and got a fix. Canon found and admitted a problem.
Don_T70
Joined Jan 2013
Feb 17, 2013 19:13 |  #12
Maybe I did not explain it correctly. I am still relatively new to this and was trying to duplicate the problem that someone else discovered. I am hand holding the camera both times with IS On. That is just some text on the wall and the image is heavily cropped. I just want new buyers of the lens to realize their might be a focusing issue with newer copies of the 24-105. Here is a capture from the post I got the info from. This is not mine. .. and I will quote the original post to hopefully help convey the message.
"Four shots were taken at each setting to show that the effect is consistent. All shots were taken hand-held with IS on. The serial number of my lens is 427xxxx, purchased in November 2012.
The IS is claimed to give a three-stop advantage, so I would expect a shutter speed of 1/3s to be usable at 24mm. At 105mm 1/13s should be usable, so at 1/5s I am slightly outside the spec. However I would not expect the IS to cause extra blurring at f5.6. The degree of blurring with IS on is somewhat worse than with IS switched off."
[Image removed]
davidc502
Feb 17, 2013 19:23 |  #13
Seems like IS is shutting off at the smaller apeture of f5/6 ..... Interesting
_
My Gear is ---> Here
tkbslc
Feb 17, 2013 21:02 |  #14
That is odd, but I would still say 1/5 at 105mm is asking a lot of an IS system.
What about 1/15? (3 stops IS correction)
Taylor
davidc502
Feb 17, 2013 22:11 |  #15
tkbslc wrote in post #15621762 (external link)
This isn't about what IS can handle... We all know 1/5 is pushing it. However, we should get similar blur points out of f/4 as much as f/5.6 with the same shutter speed.
The point is, he is not getting the same or even a similar result.
_
3,571 views & 0 likes for this thread
Latest registered member is Curlicue
919 guests, 289 members online
