Thread started 18 Feb 2013 (Monday) 10:12
Vertical Hand Strap
jbrand
Feb 18, 2013 10:12 |  #1
I have a gripped 7D. I shoot about 80% of my stuff vertically (one reason I like the grip). Mostly basketball.
Is anyone aware of a handstrap or adaptation that might work well for this?
Not a big fan of net straps or other systems, Currently wrap the strap around my wrist for some small amount of security should i "drop" it.
Welcome thoughts.
Jim
"If you can't do something smart, do something right"
Gripped 7D, Gripped 450D, Rokinon 8mm 3.5, Sigma 20mm 1.8, Sigma 30mm 1.4, Canon 40mm 2.8, Sigma 50mm 1.4, Canon 85mm 1.8, Canon 200mm f2.8L, Canon 70-200mm f2.8L, Canon 300 f4L, Kenko 1.4 TC and tubes, S95, AT-1, and a bunch of other stuff.
Don ­ Madson
Feb 18, 2013 17:35 |  #2
I'm shooting a 7D with a grip, and it LOOKS like my Herringbone handstrap has a strap that's long enough to reach from the tether point on the right side of the grip, along the bottom and up to the tether point on the top left side of the body.
Hmmmm.....I just tried it out, and it DOES work, although not with a lot of extra strap length, and my hands aren't huge.
Looking at how it's made, it might be fairly easy to swap out the strap for a longer one, then to simply thread the strap through the support pad. DIY might produce JUST what you need, with a little imagination and experimenting!
Let us know how you make out!
Don
dmadson.photoreflect.c​om
T'ai Chi Ch'uan...Relaxation, with an attitude!
70D, Mamiya 645 Pro TL, some lenses, a tripod, a monopod, some filters, a few straps, some batteries, 2 flash units, a few bags...;)
NestorV
Feb 19, 2013 01:05 |  #3
Hello. Is the E1 Handstrap something along the lines you are interested in?
Canon E1 Vertical Grip Hand Strap (external link)
jbrand
Feb 20, 2013 07:23 as a reply to  @ NestorV's post |  #4
Thanks for the reply.
I've looked at the canon, but was not sure about the vertical aspect of it. Reviews in that regard seem a bit mixed or unclear. B&H lists as no longer available.
I'll poke around a bit more. The herringbone DIY may be my option.
Jim
jbrand
Feb 20, 2013 09:35 |  #5
Ok I found a place that had the canon in stock. I just ordered it. Might not be a permanent solution, but might provide necessary parts for the DIY solution.
1,621 views & 0 likes for this thread, 3 members have posted to it.
Vertical Hand Strap
1223 guests, 166 members online
