Thread started 18 Feb 2013 (Monday) 11:25
Do you use the rear-wheel lock?
TSchrief
Joined Aug 2012
Feb 18, 2013 11:25 |  #1
There is another thread going about the rear-wheel lock not working on a 60D. That made me curious. I have a 60D, 5D and Elan 7NE. I don't use the rear-wheel lock on any of them, ever. I tried it and don't like it. I'll risk the occasional mistake over not having access to the wheel when I want/need it. I assume the feature would not be there if lots of shooters hadn't demanded it.
Please comment about the rear-wheel lock. Do you use it: never, sometimes, always?
3leggeddog
Joined Jan 2013
Feb 18, 2013 11:36 |  #2
Never have used it. For the same reason that TSchrief gave: I don't want to lose the time that it takes to unlock it, and potentially miss a good shot. Because by that point I probably would have tried to adjust the wheel, realized that it wasn't working, have to unlock it, then adjust again and compose. I like to reduce as many steps as possible.
1Ds Mk II, 10D, G15. 400 2.8 IS L, 100-400 L, 70-200 2.8 IS L, 75-300 EFII, 180 3.5 Macro L, 28-80 EFII, 17-35 2.8 L, 15 Fisheye. Uncle Pete, you were a photographer in your own league, thank you.
TSchrief
Joined Aug 2012
Feb 18, 2013 11:39 |  #3
3leggeddog wrote in post #15623517 (external link)
That is EXACTLY what happens to me. I tried it, and using it messed up WAY more shots than not using it ever did.
hwan
Joined Dec 2012
Feb 18, 2013 11:43 |  #4
I have a 5D2, and find it very annoying that I have to go 2 clicks to turn the camera on and off, since I want my wheel always unlocked. There's no way around this, is there?
Olympus E-M1 | 12-40mm f2.8 | 17mm f1.8 | 75mm f1.8 | GT1544T + Q3T
Xcelx
Joined Sep 2009
Feb 18, 2013 11:55 |  #5
I sometimes use it when I shoot full manual using the same settings over a longer period of time. The back wheel has got quite easy to turn over the years on my 5Dc from 2005 so it's nice to be able to lock it.
panicatnabisco
Gallery: 33 photos
Joined Apr 2012
Feb 18, 2013 13:25 |  #6
I use it all the time to lock in shutter speeds in manual mode so I can freely adjust the aperture. Works well in weddings and motorsports
Canon 1DX III | 1DX | 6D II | 6D | 16-35/2.8 II | 24-70/2.8 II | 35/1.4 II | 50/1.8 | 70-200/2.8 IS II | 85/1.4 IS | 100/2.8 IS macro | 200mm f/2 | 400/2.8 IS II | 2xIII
Leica M8.2 | Noctilux 50 f/1 | Elmarit 90/2.8
afimages.net (external link) | Facebook (external link) | instagram (external link)
amfoto1
Feb 18, 2013 13:40 |  #7
Yes, I use it all the time... see the other thread.
5DII, 7DII(x2), 7D(x2) & other cameras. 10-22mm, Tokina 12-24/4, 20/2.8, TS 24/3.5L, 24-70/2.8L, 28/1.8, 28-135 IS (x2), TS 45/2.8, 50/1.4, Tamron 60/2.0, 70-200/4L IS, 70-200/2.8 IS, 85/1.8, Tamron 90/2.5 Macro, 100/2.8 USM, 100-400L II, 135/2L, 180/3.5L, 300/4L IS (x2), 300/2.8L IS, 500/4L IS, EF 1.4X II, EF 2X II. Flashes, studio strobes & various access. - FLICKR (external link) - ZENFOLIO (external link)
carcrafter22
Joined Aug 2011
Feb 18, 2013 14:17 |  #8
Nope I never use it.
On a side note I recently bought my wife a 60d and can't understand why anyone would ever need the mode lock button either, makes no sense to me.
1D mark IV, Sigma 35 1.4 Art, Canon 50 1.4, Canon 10-22mm moded for 1D, 24-105L, 70-200L 2.8 IS II, 580EX II,
Jim_T
Joined Nov 2003
Feb 18, 2013 14:21 |  #9
On my 10D, I the wheel was easy to move with a slight bump of the thumb or nose.. I accidentally spoiled a few shots doing this and not noticing that the exposure settings had changed.. I've had my 7D for a couple of years now and have never accidentally moved the wheel... I don't know why for sure.. I guess it's a bit tighter or in a bit better position. I can't comment on the 60D
I prefer to leave the wheel unlocked, because it's a pain to have to take the extra step of unlocking it when needed.
gjl711
"spouting off stupid things"
Feb 18, 2013 14:24 |  #10
hwan wrote in post #15623543 (external link)
keep it on all the time. It goes to sleep anyways.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
gjl711
Feb 18, 2013 14:25 |  #11
BTW, I have used it several times but always by accident. I go to use the real wheel and nothing. Takes me a moment or two to figure out what happened.
::Gear::
xhack
Feb 18, 2013 14:33 as a reply to  @ gjl711's post |  #12
Like most here, I've always been in the all-or-nothing camp. Never used the mid-position. What's not to like about having instant exposure compensation in Av or Tv? But I'm 85% in Manual, so it's a no=brainer to have the switch up the full whack.
~ Wallace
leftnose
Joined May 2012
Feb 18, 2013 14:35 |  #13
carcrafter22 wrote in post #15624119 (external link)
The mode dial lock drive me up the wall. I had (still have, actually) an A2 and the lock broke twice on that. I then had a 5D2 and got used to not having the lock. Now, with the 5D3, I haven't regained the habit of using the lock and I'm constantly trying to twist the locked dial. I'm afraid I do this so much that I'm going to end up breaking it just as happened with my A2.
JamesDurbinMedia
Joined Aug 2012
Feb 18, 2013 14:53 |  #14
Guess I'm one of the odd ones that uses and requires the lock every day.
J.D
Staff Photographer - Hearst Corporation - Newspaper Division
TSchrief
Joined Aug 2012
Feb 18, 2013 14:59 |  #15
panicatnabisco wrote in post #15623920 (external link)
You lock the rear wheel and can adjust aperture while shutter speed is fixed? Is there a custom function to switch front and rear dials? None of my bodies can do that! I think it would just confuse me, anyway. Lots of things do these days.
3,453 views & 0 likes for this thread
Latest registered member is Phual13
790 guests, 170 members online
