I was reading through my 60D manual (pgs. 75-78) over the weekend and for the life of me can't figure something out. I use back button focusing, and predominantly keep my camera in AI Servo. I know the focus confirmation beep and light do not work in AI Servo, but do the autofocus points light up? I know that AI Servo is used for moving objects, but I often just set it to this and leave it. When I am shooting a still subject, it appears to use the center point to focus, regardless of composition or subject distance. Does this seem to be correct behavior and correct assumptions on my part? When in AI Servo I think I can manually select the AF point and it lights up, just curious why when using auto select it doesn't light up to tell you which one it is using for focus. If it always uses the center point in AI Servo, then this makes sense. Thanks in advance.
