Thread started 20 Feb 2013 (Wednesday) 02:23
flash or lens..which one to buy first
bryjosh9385
Joined Feb 2012
Feb 20, 2013 02:23 |  #1
i have a tight budget my money is can buy one of the two for now..a flash or the 85mm f1.8.. which one to get first....
CAMERA:Canon t3i(600d),18-55mm kit lens/50mm 1.8/battery grip/etc...
joeseph
"smells like turd"
Gallery: 264 photos
Joined Jan 2004
Feb 20, 2013 02:44 |  #2
more info needed... what do you shoot?
TF posting: here :-)
bratkinson
Joined Dec 2011
Feb 20, 2013 03:27 |  #3
I'm a little confused...according to your signature, you've got the 18-55 and 50mm. Although the 85mm f1.8 is a great, sharp lens, the added 'reach' of the 85mm won't be very significant over the 50 or 55 end of the zoom. So, why are you looking at the 85? For reach 'differential', I'd probably go for the 100mm, if you're looking to go with a prime.
I'd also consider selling the 18-55 and replacing it with the EF-S 18-135 f3.5-5.6 IS. That was once my favorite 'do all' lens (I've since upgraded to "L" lenses) and has a great zoom range with minimal obvious distortion (barrel distortion, largely). It's shortcoming was indoors without a flash. But you've got that covered with the 50mmm f1.8.
As mentioned above, 'what do you shoot?'.
If you're doing mostly indoor work, then a flash would definitely be #1 priority. A used Canon 580EX mark I or mark II would be a fantastic all-around flash for a long time to come. While the 440EX would probably suffice, I've always gone with the big brothers as I never know when I'll need the extra lumens. The 580s can also act as a master unit if, in the future, you opt for additional flash capabilities.
For outdoor work, like I said, I really liked the 18-135. The 55-250 would also be a good choice if you're looking for some added telephoto that 'fits' nicely with your 18-55.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." General George S Patton, Jr 1885-1945
bryjosh9385
Joined Feb 2012
Feb 20, 2013 03:47 |  #4
I shoot mainly portraits....85mm is way better that the 50mm...i want to do some creative staff....of camera flash those thing
timbop
Feb 20, 2013 04:04 |  #5
bryjosh9385 wrote in post #15630804 (external link)
agreed about the 85/1.8 - it is a MUCH better lens then the 50/1.8. While I think a flash is essential for any photographer to have, you can do a lot of portraiture without one. Personally, I would look toward the 85 and sell the 50 to fund buying a used 430EX.
Current: 5DM3, 6D, 8mm fish, 24-105/4IS, 35/2IS, 70-200/2.8IS, 85/1.8, 100-400/IS v1, lensbaby composer with edge 80, 580's and AB800's
Formerly: 80D, 7D, 300D, 5D, 5DM2, 20D, 50D, 1DM2, 17-55IS, 24-70/2.8, 28-135IS, 40/2.8, 50/1.8, 50/1.4, 70-200/4IS, 70-300IS, 70-200/2.8, 100 macro, 400/5.6, tammy 17-50 and 28-75, sigma 50 macro & 100-300
JohnB57
Feb 20, 2013 04:06 |  #6
85mm used to be considered the perfect FL for portraits on 35mm. I think it's a little tight on crop.
The Yongnuo flash units are pretty good - I use one alongside my 430EX - and the newer ones work with the wireless trigger on the 600D. Might be worth going for this cheaper option if you're at the experimental stage.
At normal subject distances and apertures, there isn't too much difference between the 430EX and 580EX (GNs 43 and 58 respectively) but the wireless control flexibility of the 580EX is worth having if you ever buy a body without wireless or internal flash.
Uncle ­ Flash
Joined May 2012
Feb 20, 2013 04:08 |  #7
I was in a similar boat and ended up buying a 580EXII on sale. The 430EXII is selling very cheap at the moment and I think you can also use it wireless with the 600D. Lots of fun.
Big dreams, small wallet.
timbop
Feb 20, 2013 04:10 |  #8
you might also consider getting a reflector for lighting portraits, such as a 2 sided light gold/white one. it requires an assistant, but it's very useful for soft lighting
timbop
Feb 20, 2013 04:16 |  #9
JohnB57 wrote in post #15630824 (external link)
Have to respectfully disagree - I prefer 135+ for portraiture on full frame, and the 85 on a crop gives an angle of view equivalent to 135mm.
As for getting a 580: it is true that it can be a master, but in order for it to be meaningful you need another flash to act as slave - and the 430 fits that bill. In a tight budget, I would suggest getting the 430 now and later on if you need to have a flash as master THEN get a 580 to trigger the 430.
Uncle ­ Flash
Joined May 2012
Feb 20, 2013 04:35 |  #10
In the meantime, the 430EXII could be triggered by the camera's integrated speedlite thingy.
JohnB57
Feb 20, 2013 05:35 |  #11
timbop wrote in post #15630837 (external link)
Hi. 85mm on crop is a little tight for me, given the space I have. It wasn't a black/white comment! Looking back at my best portraits, the best crop ones were taken at or around 50mm, so that kind of bears out my own needs and preferences.
Equally, on the 580EX, I was only offering the advice based on my own experience that it may offer future flexibility with a second cheaper unit.
The best advice merely explains all options based on personal experience, don't you think?
Zatx
Joined Jan 2013
Feb 20, 2013 06:53 |  #12
No question about it.. indoor portrait photography will benefit the most from a flash over another lens at the moment. You can take some great portraits with the lenses you have right now and a good flash. I love my YN-468 flash that only cost me $99.00.
Here is an amateur shot with the kit lens you have and the YN-468 flash. I bounced the flash off of the white ceiling to fill the room with light.:
Current Gear: Canon T4i (gripped), Canon 10-22mm, Sigma 30mm 1.4, Canon EF 85 1.8, 18-55mm Kit, 55-250mm, Yogo YN-468 Flash, LR 4, Carryspeed Slim, lots of bags.
Feedback: https://photography-on-the.net …p?p=15639404#po​st15639404
timbop
Feb 20, 2013 12:09 |  #13
JohnB57 wrote in post #15630922 (external link)
Yes, so I was giving counterpoints to your points :D
And now for a windowlight portrait at 100mm on 7d:
http://www.facebook.co​m …5577795999&type​=3&theater (external link)
BrickR
Joined Mar 2011
Feb 20, 2013 15:02 |  #14
Having another 1.8 lens will give you a little more compression but it won't improve the quality of your light.
Light is what photography is all about so I would upgrade my lighting first if I was doing portraits. I use my 50 1.8 for portraits a lot on my crop bodies. The FL on a crop is good for 1/2 body and up, even 3/4. Constant light can be an inexpensive option to improve your lighting for portraits if you don't want to spend a lot.
My junk
The grass isn't greener on the other side, it's green where you water it.
Fester
Joined Sep 2011
Feb 20, 2013 15:07 as a reply to  @ BrickR's post |  #15
With out reading all the reply's and know your specifics, I can say since I went off camera on flash, it has opened up so much more creative outlets for me. Instead of more lenses I bought another flash and now wireless triggers to get me more flexibility with the flashes. And Yes Flash will help outside and in bright light too!
So my vote for you is FLASH
2,654 views & 0 likes for this thread, 11 members have posted to it.
1278 guests, 121 members online
