Thread started 20 Feb 2013 (Wednesday) 08:19
580 EX ll Reliability/Longevity?
Pitter
Gallery: 16 photos
Feb 20, 2013 08:19 |  #1
I have owned a 580 EX ll for about a year with a 7D. It is the version with the pointy contacts. I have had occaisional problems with it where it turns on in TTL mode and I'd have to remove and replace the batteries and remove and replace the unit on the mounting plate in order to get it to open in ETTL mode. Always solvable though with some fiddling. Now however I have a serious problem. The flash will only fire one or two times out of ten (allowing adequate recycle time) even though it's screen is on and shows no errors. Doesn't matter what camera shooting mode, M, Av etc., ETTL or ETTL High Speed. I have tried the usual; remove, replace the unit on the camera, remove replace the (fresh) batteries and so on. It has been used almost daily for much of that year. Could it just be worn out? Any ideas? Thanks.
SYS
Gallery: 602 photos
Joined Jul 2004
Feb 20, 2013 08:30 |  #2
Out of curiosity, what kind of batteries are you using for the flash?
-Goethe
butterfly2937
Gallery: 378 photos
Feb 20, 2013 12:03 as a reply to  @ SYS's post |  #3
I highly recommend Eneloop rechargeable batteries. I have 3 x 580 EXII flashes that I have had for several years and no problems. Make sure you always use freshly charged batteries. I also only use Phottix odins with them for off camera flash and so far the combo has been 100% reliable.
GEAR
Pitter
Gallery: 16 photos
Feb 20, 2013 16:12 |  #4
@sys I'm using Powerex 2700 rechagable.
jdpence
Feb 20, 2013 19:27 |  #5
I've had my 580EX II for about 4 years now and have it almost permanently mounted to my camera. I don't think you've worn yours out. I have had a similar problem a couple of times that was caused by the flash not being seated properly on the hotshoe. Once I pushed it further onto the hotshoe and made sure the locking lever is tight it behaved properly.
Jeremy
Engineer by day...Amateur Photographer whenever I can find time for it
https://photography-on-the.net/forum/showthre​ad.php?t=591727
jgogums
Feb 22, 2013 00:23 |  #6
Pitter...I had to send my 3 yr. old 580exII to Canon for repair. Had the same problem you are experiencing. It cost around $200 to fix. Don't have invoice in front of me to tell you what they replaced. But, works perfect now.
samsen
Feb 22, 2013 01:10 |  #7
I love 580 but the bottoms are not as clear as 550. You need to have a manual nearby.
As for rest, I have had no problem.
Weak retaliates,
Strong Forgives,
Intelligent Ignores!
Samsen
Picture editing OK
apersson850
Obviously it's a good thing
Gallery: 35 photos
Feb 22, 2013 08:17 as a reply to  @ samsen's post |  #8
I guess you mean buttons...?
I've had my first 580 EX II for more than five years now. No issues.
Anders
DanPics
Feb 22, 2013 16:57 as a reply to  @ apersson850's post |  #9
I use Engergizer rechargeables with my three 580 EXII flashes and the work great.
Pitter
Gallery: 16 photos
Feb 22, 2013 20:50 |  #10
jgogums interesting. Thanks for mentioning that. Looks like a turn in the repair department is in order. I'm glad others have had such good luck with their units but of course I posted in hopes of getting a handle on the very serious problem I have with mine.
Robert ­ Welch
Joined Apr 2012
Feb 22, 2013 21:26 |  #11
Pitter,
It does sound like in needs servicing. Is it just one year old? Unless you are using it all day, every day for a year, it really should last longer than that. But they can fail, even when new. If you aren't a CPS member, certainly sign up and send it to them, they'll fix it up for you. It will probably be in the $200, as someone else mentioned, unless it's still under warranty.
Pitter
Gallery: 16 photos
Feb 23, 2013 06:34 |  #12
Robert W it's two years old. Thanks for the CPS tip.
FreddyHFK
Joined Jan 2013
Apr 21, 2013 13:36 |  #13
Hello!
I have a problem with a Canon Speedlite 580EX II. Whatever the mode and settings that I use triggers only at maximum power. and the preflash for ETTL mode it triggers at the maximum ori if i press the pilot..
Has anyone encountered this problem?
FEChariot
Gallery: 13 photos
Joined Sep 2011
Apr 21, 2013 14:49 |  #14
FreddyHFK wrote in post #15851803 (external link)
Hello!
Is the flash seated all the way forward on the hot shoe? Make sure it's pushed all the way in.
Canon 7D/350D, Σ17-50/2.8 OS, 18-55IS, 24-105/4 L IS, Σ30/1.4 EX, 50/1.8, C50/1.4, 55-250IS, 60/2.8, 70-200/4 L IS, 85/1.8, 100/2.8 IS L, 135/2 L 580EX II, 430EX II * 2, 270EX II.
FreddyHFK
Joined Jan 2013
Apr 21, 2013 15:56 |  #15
even with the flash off camera using only pilot button for test, in ETTL or Manual mode. in any case it triggers only on maximum power
4,656 views & 0 likes for this thread, 17 members have posted to it.
2232 guests, 126 members online
