I rarely, if ever, use Mini-Bridge from within CS6. In the past I think you had to have Bridge running to access Mini-Bridge, so I never used it. This thread (https://photography-on-the.net …/showthread.php?t=1276253) had me looking at a couple of things and I noticed that now Mini-Bridge will run without Bridge running, although it appears to make some sort of connection and run in the background. I was taking a look at Mini-Bridge this morning and noticed several corrupted images in some older folders. I then opened Bridge and the same image was ok. I'm thinking that Amber's (and others) problems may be partly with Mini-Bridge and maybe the way it's reconfigured to run. Anyway, here is a screen grab of the same image in Mini-Bridge, Bridge, ACR7.3, and CS6.
Any other thoughts?
