Thread started 21 Feb 2013 (Thursday) 20:38
70-200 on a T2i
Canon11385
Joined Oct 2011
Feb 21, 2013 20:38 |  #1
are there any issues with communication between the 70-200 line and a T2i. cause I borrowed my uncles f4 IS and I felt like the auto focus was acting a little weird. any thoughts?
Im better behind the lens then in front of it.
gjl711
"spouting off stupid things"
Feb 21, 2013 20:40 |  #2
Shouldn't be, define weird.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
Canon11385
Joined Oct 2011
Feb 21, 2013 20:43 |  #3
it was having trouble trying to focus on an object and sometimes I felt like the auto focus didn't move at times. when I asked my uncle if he had any problems with it (he has a 7d) he said no.
Samuel ­ Adams
Joined Dec 2011
Feb 21, 2013 21:08 |  #4
Was the focus point very close to you? That is the only time my 2.8 might have an issue. Minimum focus distance is 1-2 meters I think?
Canon 5D mkIII | Canon EF 70-200mm f/2.8L IS II | Canon EF 17-40 f/4L | Canon EF 85mm 1.8
Feedback
www.dougsowellphotogra​phy.com (external link)
maverick75
Joined May 2012
Feb 21, 2013 21:11 |  #5
Well natively the 7D has a better auto-focus than the T2i. But it still shouldn't be bad at all, unless you're shooting in dim light.
Where you shooting outdoors or indoors? were you on single focus point or?
AI Servo or 1 shot?
gjl711
Feb 21, 2013 21:26 |  #6
Dim light or low contrast. trying to focus on a white wall in full sunlight is also difficult. Though the 7D AF is better, there is no reason a t2i should not be able to focus other than dim light or poor contrast.
::Gear::
klr.b
Feb 21, 2013 21:46 |  #7
Check the focus limiter switch.
gordon
Gear and Feedback
gremlin75
Feb 21, 2013 23:38 |  #8
Canon11385 wrote in post #15638016 (external link)
That statement concernes me a bit as the f4 IS's Af (actually it's not just the AF as it effect MF as well) has been known to crap out.
To test it just turn the focus ring to make sure the lens will go though its full range of focus, from close to infinity and back. Do this with the lens level to the ground, with it angled up, and with it angled down.
If it will not go though the full range of focus and back again then tell your uncle its time to send the lens to a canon service center and the repair will be about $180.
When that happened to my lens, while angled up, it would go from infinity to close but not back and while angled down it would go from close to infinity but not back (or vice versa, don't remember).
May not be the issue but its a simple thing to test and an easy thing to rule out.
ceegee
Feb 22, 2013 07:32 |  #9
Check the minimum focusing distance. There's a switch on the lens. Could be you're just too close to your subject.
Gear: Canon R10, Canon RFS 18-150, Canon RF 100-400
Canon11385
Joined Oct 2011
Feb 22, 2013 14:42 |  #10
I was able to manual focus so we are good there I was about 5 feet away to a lamp.
gjl711
Feb 22, 2013 15:50 |  #11
Canon11385 wrote in post #15640888 (external link)
Minimum focus distance of the 70-200 f/2.8 is right at 5 feet so it's very possible that you were below the minimums. It might have looked ok manually focused but still been a little bit off. Try it again a little farther away.
::Gear::
1,304 views & 0 likes for this thread, 7 members have posted to it.
70-200 on a T2i
1391 guests, 126 members online
