If you have this on your machine, and it's recent, unload it and then use System Restore to get back to the state before you loaded it RIGHT NOW.
If you loaded it a long time ago and haven't noticed anything bad you're in deep kimchee. Hope you have a system load disk (not a "recovery disk", an original Windows 7 load disk) -- because you need to do a repair install after unloading this piece of trash.
It appears that the damage has been known since at least November of last year, when some Adobe people started running into problems with Lightroom 4 and Premiere failing to load with an obscure error. Tracing it revealed damage to two system DLL files, which are supposed to be impossible to overwrite through normal means (and they are, in fact.) The problem is that there's a way around it, and the installer for this thing appears to use that way around the restrictions.
Removing the software does not restore your machine to its prior state. There are workarounds for the impacted Adobe applications but that does not unscrew your machine in the general sense.
All x64 (64-bit) machines running Windows are potentially impacted but the damage often does not show up until you load a specific x64 app (like Premiere) that malfunctions. In the case I'm dealing with right now the damage itself happened in December -- detection of it was LAST NIGHT. So much has been done since that restoring either a backup or using System Restore from that time would destroy ridiculous amounts of work, so I am attempting a non-destructive fix, and it's taking a hell of a long time (and is not yet completely successful either.) I'm very good at ferreting out what's going on and fixing these things on Windows machines folks, been doing this sort of thing since the first days of Windows, and thus far I'm six hours of effort into this one with only a PARTIAL set of success thus far. It's that bad; were this a machine where the user would not have a cat if I just reloaded it from scratch I would have done that last night. As it stands I'm going to exhaustion first in an attempt to avoid having to screw with the program and data environment that will have to be re-created if I am forced to do a bare-metal reinstall.
One of the symptoms that you've been bit by this is that the Microsoft Camera Codec pack doesn't work. That is, you load it, it appears to load just fine but you can't see any previews of raw files in the explorer nor view them with the windows picture viewer.
If your machine is doing that there's a high probability you've been nailed by this and you're on borrowed time.
The company has a Facebook page, nearly 600,000 "likes" (is obviously promoting itself on Facebook) and the firm's web page's "contact us" link doesn't actually go to a way to contact them. Download.com has pulled its link.
Beware -- this is a nasty one in that it's not, apparently, a formal "virus" per-se but it utterly screws your machine's configuration, there is no easy fix (if any fix at all other than a reload) -- and it's reliably repeatable.
