Lowner wrote in post #15844543
The advise I have taken to heart says that one should sharpen on import (straight out of camera), then again during post processing and finally do a pre print sharpen. So a 3 stage approach.
That needs a little elucidation for those who are not familiar with the 3 stage method:
1. Stage one, also called Capture or Input sharpening, should be minimal. The goal is not a great looking image, but merely to rectify the effect of the anti-aliasing filter in front of the sensor.
2. Stage two, also called Creative sharpening, will typically address local issues within the image such as the eyes in a portrait or might be limited to edge sharpening with an appropriate mask. It might even be accompanied by its opposite, blurring/smoothing of selected areas like skin smoothing in portraits or NR applied through a surface mask.
3. Stage three, Output sharpening, is delayed until the end primarily because any resampling, up or down but mostly upwards, will change the amount and kind of sharpening needed.
