Thread started 25 Feb 2013 (Monday) 00:46
50mm 1.4 or 85mm 1.8?
rivas8409
Joined Mar 2011
Feb 25, 2013 00:46 |  #1
I've been eyeballing a Canon 50mm 1.4 and a Canon 85mm 1.8 and I decided I don't need both so I'm wondering which you guys would recommend.
Body: Canon 5DmkII│Canon M50
Glass: Tamron 35mm f/1.4│Canon 85mm f/1.8│Canon 24-105mm f/4L│Canon 135mm f/2L│Canon EF-M 22mm f/2.0
Lights: Flashpoint XPLOR 400PRO│Flashpoint Streaklight 360│Flashpoint Zoom Li-on│AB800
Results: WEBSITE (external link)FACEBOOK (external link)
J.Doe
Joined Mar 2011
Feb 25, 2013 02:24 |  #2
Assuming that you're gonna keep the 50D body:
You already have a 50 thus I don't see the need of another (though "faster",but really not very usable up to f/2).
On the other hand,the 85/1.8 you're looking at could be a fine compliment to the lenses you have already.Aside that it's IQ and build is really great for what it costs,it should be the longest in your lineup (think at it in terms of FOV:85 x 1.6 = 136,so you're in the 135mm-lenght ballpark,in case you aim towards closeup portraits...but not only).
HTH!
Cheers,
60D,MKIIn,Ds MKIII __EF 50 f/1.4,EF 100 f/2.8 macro,EF 135 f/2.0L,EF 16-35 f/2.8 L II,Tamron 28-75 f/2.8,EF 70-200 f/2.8L,Tamron 70-300 f/4-5.6 VC USD ,EF 2xII TC__Marumi clear glass,UV,ND & CPL__ Kata bags__Speedlite 580EX & Metz 58 AF-2 w/Eneloops__ Sandisk __Vanguard Alta Pro 263AT & TRACKER AP-364 w/SBH-300's
rvank
Joined Feb 2013
Feb 25, 2013 09:28 |  #3
I have both and love both. The 85 is far and away a much cleaner lens, especially wide open - far less corner softness, less vignetting, better color and contrast. I find the 50 1.4 too soft to shoot wide open and I often have to stop it down to 2.0 before I'm happy with it but it is still a great lens - that extra half stop over the 1.8 can come in handy when you absolutely have to use it.
All that being said, is there anything particular you're looking to shoot with this new lens?
Russell van Kraayenburg
Chasing Delicious (external link) | The Boys Club (external link) | thesweettooth.co (external link)
5D MK II | 7D | ELAN7 | 24-70 2.8 | 24-105 4 | 70-200 4 | 28 2.8 | 50 1.4 | 85 1.8 | 200 2.8 | 300 4
jdpence
Feb 25, 2013 11:48 |  #4
85 1.8 is a great lens but could be somewhat limited in its use on your 50D.
Jeremy
Engineer by day...Amateur Photographer whenever I can find time for it
https://photography-on-the.net/forum/showthre​ad.php?t=591727
Motor ­ On
Feb 25, 2013 11:57 |  #5
You've already got a 50, get the 85. I've got both the 50 1.4 and the 85 1.8, the combinations make good compliments to each other, even on a crop. My 85 tends to see a little more use than the 50, my 135 sees more use than both of those.
Website (external link) | Facebook (external link) | Instagram (external link)
tkbslc
Feb 25, 2013 12:03 |  #6
rvank wrote in post #15649766 (external link)
I tend to agree with that assessment, but considering the 85mm f1.8 is also a little better stopped down to f2-2.2, we are at a level playing field. Both are excellent at f2+, but the 50mm still has a stop in reserve. It's also not bad at those larger apertures if you are careful to centrally place your subject.
In terms of low light, consider 50mm gives about a stop of advantage based on focal length, and then adds in nearly another stop due to max aperture. In the dark, you might be at 50mm, 1/100, f1.4 and ISO 3200, where you'd be at 85mm, 1/160, f1.8 and ISO 12800 on the 85mm. (I think that math is right, it's about 1.66 stops difference)
Taylor
EOS Rp | iPhone 11 Pro Max
1,646 views & 0 likes for this thread, 6 members have posted to it.
1361 guests, 131 members online
