Thread started 25 Feb 2013 (Monday) 13:08
MP-E and 2X TC
Lester ­ Wareham
Moderator
Gallery: 3035 photos
Best ofs: 5
Feb 25, 2013 13:08 |  #1
Any one see the macro-photography article in March Outdoor Photography?
The author is using the MP-E and twin flash with a 2X TC to get up to 10x magnification. He also stops right down to f14 at times.
I remember experimenting with a 2X on the MP-E when I first got it, but to be honest I thought it was dark enough already.
Macrophotography by LordV
Martin ­ G.
Feb 25, 2013 17:13 |  #2
thanks for the tip, will try to get a copy. How are the results?
6D & 70D
EF 24-105 L, EF 40mm, EF 85mm f1.8, EF 100mm L IS, MP-E 65
Macro Twin Flash MT-24EX, 430 EX II & 270 EX
Lester ­ Wareham
Moderator
Best ofs: 5
Feb 26, 2013 00:14 |  #3
Martin G. wrote in post #15651415 (external link)
The results looked fine, but the photos were generally small, so even at a high print DPI it is difficult to judge fine detail sharpness.
samsen
Feb 26, 2013 00:20 |  #4
Macro means a lot of work.
Weak retaliates,
Strong Forgives,
Intelligent Ignores!
Samsen
Picture editing OK
Martin ­ G.
Feb 26, 2013 06:40 |  #5
Lester Wareham wrote in post #15652732 (external link)
OK thanks
6D & 70D
Snowyman
Gallery: 682 photos
Joined Oct 2011
Feb 26, 2013 09:28 |  #6
I wouldn't like to chase a wasp around with that rig. :shock:
Snowy's Gear
Deviant Art (external link)
500px (external link)
Lester ­ Wareham
Moderator
Best ofs: 5
Feb 26, 2013 14:21 |  #7
I think 8-10x must very hard in the field, I find 3-4x the limit for field due to movement of the subject due to air currents etc. I do use the twin flash and MP-E in the field a lot, adding the 2x II would not be a big issue.
I did wonder if some of his high mag shots were studio ones however, just from a practicle point of view.
gatorlink
Joined Mar 2011
Feb 26, 2013 18:09 |  #8
I am skeptical that shooting at f/14 with the 2x would look good at an any decent size. From what I have heard from those who have tried it, that combo produces somewhat soft results even when shot at wide apertures.
Eddie Nurcombe takes handheld focus stack up to 10x using a ton of extension tubes (see the photo below for an example of his setup), and his stacks come out wonderfully sharp when shot at wide apertures. I have not tried tubes or the 2x, but if I wanted to try shooting at 10x, I would surely go for the tubes and not the 2x.
http://www.flickr.com …8485636613/in/p​hotostream (external link)
Ryan
Canon ­ Bob
Feb 27, 2013 09:07 as a reply to  @ gatorlink's post |  #9
Working at 10x produces its own set of unique challenges and sometimes a 2x has benefits that outweigh the disadvantages of IQ deterioration.
Tubing the MP-E to 10x gives a working distance of around 15mm and this presents the challenge of how the illuminate the front of the subject given that a full 7 stops of light will be swallowed when compared to normal aperture calculations (ie, f/2.8 is effectively f/32 in expsoure terms). Current bodies like the 1Dx will given you 5 of those stops before noise reduction processing nullifies the advantages but that's where the help stops in practical terms. A 2x will not impact on the working distance an IQ loss is the main worry.
After around 7x magnification, I turn to the older Macrophoto lenses (20mm and 35mm) on a bellows setup. The front on the lens assemblies are chamferred to permit light to be directed at the front of the subject with greater ease.
Bob
1Dx2 (2), 5DSR, 1Ds3, 1D4, 5D2(590nm), 5D2(720nm) EF600 EF400 EF300-II EF300 EF200 EF200-II EF180L EF135L EF100 EF85-II EF50L TS-E17/4 TS-E24L-II TS-E45 TS-E90 MP-E65 EF70-200-II EF24-70/2.8-II EF16-35/4 EF8-15/4 EF11-24/4 Zeiss 15/2.8 21/2.8 25/2 28/2 35/1.4 35/2 50/2 85/1.4 100/2 135/2 T/C's L-SC & a WIFE!
Lester ­ Wareham
Moderator
Best ofs: 5
Feb 28, 2013 00:21 |  #10
Ryan I agree about the high f numbers, over 1x-2x I tend to limit to f/8 or less and stack, I suspect this is why the images are reproduced small.
Bob, yes I wondered about lighting, the lighting in his shots look quite good. I certainly have difficulty with less magnification. Although his emphasis was on the twin flash a ring flash was also mentioned. I didn't notice any ring highlights however.
Note his route to 10x was a 2x rather than more extension so the minimum working distance was not affected. He notes an expected loss of image quality with more glass, but stopping down so much probably does not show it up by comparison. Although he seems to use more conventional f stops with less magnification.
1,602 views & 0 likes for this thread, 6 members have posted to it.
MP-E and 2X TC
2956 guests, 133 members online
