Thread started 04 Mar 2013 (Monday) 09:17
First Flash
dhornick
Gallery: 31 photos
Joined Oct 2012
Mar 04, 2013 09:17 |  #1
I tried to search first but didn’t really see what I was looking for. Looking to add my first flash unit to the equipment pile. Any preferences from you guys? I'm looking at either the Speedlite 430EX II or the 320 EX. For now let’s just say it will be used for general shots, indoor portraits and maybe some outdoor landscape, portrait type stuff.
Darrell
6D | 16-35mm f/4 L | 8-15mm Fisheye L | 24-105mm f/4L | 24-70mm f/2.8L | 100-400mm f/4.5 5.6L | Speedlights 430EX III, 600EX II RT & ST-E3-RT transmitter.
chrismarriott66
Gallery: 14 photos
Joined Jan 2012
Mar 04, 2013 09:21 |  #2
Between those two, I'd say go for the 430 - it will certainly do you for the types of shots you've mentioned :)
Chris Marriott Photography (external link)| Facebook (external link)
Complete Gear | 1ds iii | 5d iii | 50d | EF 16-35 f2.8 L USM ii | EF 24-70 f2.8 L USM | Σ 70-200 f2.8 ii EX DG HSM | Σ 35mm f1.4 Art | EF 50mm f1.4 USM | EF 85mm f1.8 USM | EF 85mm f1.2 L USM ii | 600EX-RT | 580EX ii | 430EX ii | YN622Cs |
tonylong
...winded
Gallery: 60 photos
Mar 04, 2013 12:16 |  #3
I don't know about the 320 EX. In general, I'd say get what you can afford. If you can't afford a 580EX then go for the 430, but I'd plan on a 580 in the future.
In the meantime, you might read up on a "bounce card"...
Tony
IslandCrow
Mar 04, 2013 14:09 |  #4
The 430 is going to give you much more versatility. I don't believe the 320 gives you much, if any, manual control of the flash. The extra power of the 430 is going to be very helpful as well. If you can afford it, the 580 is a great flash with built in capability to wirelessly control other Canon flashes, but otherwise the major difference between it and the 430 is significantly greater power.
samsen
Mar 04, 2013 14:17 |  #5
^^ ditto.
Weak retaliates,
Strong Forgives,
Intelligent Ignores!
Samsen
Picture editing OK
ejenner
Gallery: 66 photos
Joined Nov 2011
Mar 04, 2013 17:35 as a reply to  @ samsen's post |  #6
^^ x2
I guess the 580 is going to be pretty large - I find the 430 quite large and have contemplated getting something smaller but as a compliment, not a replacement, for times I don't need the power or versatility of the 430. Unless you know you are going to need maximal power the 430 is a good start - even if you do need external flash control you can control it with a 580 or other controller.
Edward Jenner
5DIII, 7DII, M6, GX1 II,M11-22, Sig15mm FE,16-35 F4,TS-E 17,Sig 18-250 OS Macro,M18-150,24-105,T45 1.8VC,70-200 f4 IS,70-200 2.8 vII,Sig 85 1.4,100L,135L,400DOII.
http://www.flickr.com/​photos/48305795@N03/ (external link)
https://www.facebook.c​om/edward.jenner.372/p​hotos (external link)
jdpence
Mar 04, 2013 19:15 |  #7
I've had a 580EX II for several years and just picked up a 430EX for my wife. Having played with the 430 a little (which is significantly smaller than the 580), I think it is a great value for an introductory flash.
Jeremy
Engineer by day...Amateur Photographer whenever I can find time for it
https://photography-on-the.net/forum/showthre​ad.php?t=591727
Bumgardnern
Mar 04, 2013 21:40 |  #8
If you are wanting to stick with a hot shoe flash check out an older Nikon SB24, or SB26, Vivitar 285HV, or one of the Nissin or Youngnuo flashes. Nothing against the more expensive ones but all of these are great values.
I have a 285HV and a 580EXII that I have been using for 5 years of steady use. The 285HV has been just as reliable as the 580EX.
watt100
Mar 05, 2013 04:23 |  #9
dhornick wrote in post #15674860 (external link)
those are good although you might want to ask in the flash section. I've been using yongnuo ETTL flashes for years.
1,078 views & 0 likes for this thread
First Flash
Latest registered member is AvroPiklu
521 guests, 335 members online
