Thread started 04 Mar 2013 (Monday) 09:33
Canon Sensor Development News
tickerguy
Joined Dec 2012
Mar 04, 2013 09:33 |  #1
http://www.canon.com/n​ews/2013/mar04e.html (external link)
Oh my.... NOW you're F*d Exmor users...
Canon wrote:
TOKYO, March 4, 2013—Canon Inc. announced today that the company has successfully developed a high-sensitivity 35 mm full-frame CMOS sensor exclusively for video recording. Delivering high-sensitivity, low-noise imaging performance, the new Canon 35 mm CMOS sensor*1 enables the capture of Full HD video even in exceptionally low-light environments.
The newly developed CMOS sensor features pixels measuring 19 microns square in size, which is more than 7.5-times the surface area of the pixels on the CMOS sensor incorporated in Canon's top-of-the-line EOS-1D X and other digital SLR cameras. In addition, the sensor's pixels and readout circuitry employ new technologies that reduce noise, which tends to increase as pixel size increases. Thanks to these technologies, the sensor facilitates the shooting of clearly visible video images even in dimly lit environments with as little as 0.03 lux of illumination, or approximately the brightness of a crescent moon—a level of brightness in which it is difficult for the naked eye to perceive objects. When recording video of astral bodies, while an electron-multiplying CCD,*2 which realizes approximately the same level of perception as the naked eye, can capture magnitude-6 stars, Canon's newly developed CMOS sensor is capable of recording faint stars with a magnitude of 8.5 and above.*3
Canon 7D & 5d3, EF-S 15-85, 24-105L, 70-200L f/4 IS, 100mm Macro/L, EF 50 f/1.4 and more
Allan.L
Mar 04, 2013 09:35 |  #2
Soooo when does this move to DSLR tech?
2n10
Gallery: 81 photos
Joined Sep 2012
Mar 04, 2013 09:36 |  #3
Probably won't translate to DSLR since the pixel size is so large or not very soon.
John
Equipment
My Portfolio (external link)
tickerguy
Joined Dec 2012
Mar 04, 2013 09:37 |  #4
Uh, yes it will. It's a 35mm sensor.
It's a HD-video sensor, which means it will show up in VIDEO cameras (it doesn't have the number of pixels of current full-frame dSLR STILL sensors), but still....
Incidentally the noise-reduction technology they came up with (which is the limiting factor for high ISO recovery) appears to be something that would immediately translate into dSLR-density full-frame sensors as well.
CoPhotoGuy
Joined Feb 2013
Mar 04, 2013 09:37 |  #5
Allan.L wrote in post #15674917 (external link)
When they are able to figure out how to make the pixels smaller.
CoPhotoGuy
Joined Feb 2013
Mar 04, 2013 09:39 |  #6
tickerguy wrote in post #15674927 (external link)
35mm sure....but would you want a brand new FF DSLR with this sensor that has a say 1920x1200 resolution?
tickerguy
Joined Dec 2012
Mar 04, 2013 09:41 |  #7
No, but I would want a FF dSLR that had the high-iso noise reduction they figured out in THIS sensor in my dSLR, which would further push the capability to capture images with a low noise profile, and I might be VERY interested in a video camera with a HD sensor that can capture at 0.03 Lux!
CoPhotoGuy
Joined Feb 2013
Mar 04, 2013 09:43 |  #8
tickerguy wrote in post #15674942 (external link)
But you just said "Oh duh it's a 35mm sensor" but in order for it to work in a DSLR the pixel size will have to be smaller. When the pixels become smaller and more densely packed, you can end up with more noise. The sensitivity part could also be due to the size of the pixels where when reduced loses the effectiveness. You simply can't plop this technology into a DSLR sensor and expect it to work.
gjl711
"spouting off stupid things"
Mar 04, 2013 09:44 |  #9
Hmm.. This seems to buck the current web lore. So if I'm understanding it right, big pixels are bad.
I'm guessing that the writer meant to say that though noise may increase, so does signal so the S/N does not.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
tzalman
Fatal attraction.
Mar 04, 2013 11:33 |  #10
Somehow I don't think there will be a big market for 3 MP cameras, except maybe among coal miners.
Elie / אלי
gjl711
Mar 04, 2013 11:44 |  #11
tzalman wrote in post #15675372 (external link)
The market is huge for industrial and security uses. Pretty much every public building has at least one camera, some have hundreds. They could make a killing in Vegas where each casino could have thousands.
::Gear::
JohnB57
Mar 04, 2013 11:49 |  #12
Mega picks and very large shovels presumably..?
pwm2
"Sorry for being a noob"
Mar 04, 2013 12:11 |  #13
Note that Canon already have quite good noise handling in their current sensors. The issue Canon have, is to be able to balance the reading between neighbour pixels.
And the article about the new sensor specifically says that the noise improvements of this new sensor is to reduce the amount of noise that happens when you read out data from very large pixels. So that would indicate that it may not be applicable for a sensor for still images, where we wants much more (and smaller) pixels.
Lowner
"I'm the original idiot"
Mar 04, 2013 12:25 |  #14
Does not get us any nearer a Canon answer to the D800/D800E. I wish Canon would forget this obscession with video and start thinking seriously how they intend to beat Sony and Nikons Exmoor sensor and processor.
Richard
pwm2
Mar 04, 2013 12:35 |  #15
Lowner wrote in post #15675571 (external link)
Gee. Not sure if you know. But DSLR is only one of many branches Canon works with. Why should they ignore video just because they currently have a fight on their hands to find a work-around for the Sony patent about balancing channels? You think Canon gets more resources to solve the noise issues, if they ignore their other branches and take an economic hit there?
2,904 views & 0 likes for this thread, 15 members have posted to it.
1441 guests, 135 members online
