Stuuk1 wrote in post #15676226
Hi Guys,
After a little bit of a nightmare with shooting in jpeg and then DPI questions etc i just want one thing cleared up without de-railing too much.
My question is:
What is the first thing you do with your RAW files?
You get home from your day of shooting in RAW only (not interested in jpeg anymore), you open your memory card on your computer and you see all of your files.
Copy and paste these to a folder on your desktop of External HD. Open your first file in photoshop (or whatever programme) and then......
You mention shooting in Raw, what Raw software do you use?
Do you straight away save that image to a certain DPI, PPI, Height, Width?
I don't convert to/save to an image file unless and until I am "outputting" -- I use Lightroom and my Export dialog is currently set to outputting at 300ppi, simply because I was planning a major printing project for which I wanted to resize the image to a specific print size @ 300 ppi. For most purposes the ppi doesn't matter to me, especially since I Export for uploading to my Web host in which case the ppi "tag" doesn't affect the display of my images. I'll crop for the "best" composition or for some other practical purpose, then when I Export for the Web Lightroom resizes the image to my specified pixel dimensions.
Do you edit the image, crop to what looks nice?
Sure, produce an image that is visually pleasing
As you can see I'm a little confused but want to get it right first off.
In the past I have literally opened the file in PS and edited away without thought and cropped to whatever looks nice. I am then stuck with 72dpi and save as a jpg which seems to be causing problems at the moment with friends that have wanted a couple of prints.
Canon cameras are "stuck" on a ppi "tag" of 72ppi. Fortunately that tag doesn't have a negative effect on most things, although some commercial printers will refuse to cooperate unless you change the "tag", typically to 300 ppi. In photoshop you can do this in the Image Size dialog -- change the ppi value without resizing/resampling the image -- the image resolution will remain the same, but the image "tag" will be changed in the Exif. Other apps let you set the resolution tag "on the fly" -- Lightroom during export, DPP during the Convert and Save operation.
Any help would be great, I planned to keep this short and sweet but seen to have gone on a bit!
Thanks.
