Thread started 06 Mar 2013 (Wednesday) 10:17
Needing Audio Help
extrememc
Mar 06, 2013 10:17 |  #1
This is my first time doing video. I interview a couple with a T3i, audio techinca lavatr-3350 run it through a juicelink ds214 with the gain set to low. You will see in this video that the gentleman voice is way lower then his wife. I would like to know beside him speaking lower. What could I have done different to achieve better quality audio? How can make it sound like his wife's voice or close? I am using premiere to edit. When I tried to raise the gain in premiere I could hear a hiss. I am sure this is the auto gain from the camera. If I am not mistaking. I do have sony vega which included sound forge. If it will work better for correct the problem. Any comment, critique, are welcomed. I just hope I can save this audio. I hate growing pains!:oops:
http://youtu.be/oZWKil​9tZj8 (external link)
Photography is an expression of the mind!!!!!!!!!!!!!
30D T3i 7D 1D MkIII Canon Eos M
Channel ­ One
Joined Nov 2010
Mar 06, 2013 17:59 |  #2
extrememc wrote in post #15683330 (external link)
It sounds like you left the lav on her while interviewing him.
Wayne
Do what you love and you will love what you do, that applies to both work and life.
extrememc
Mar 06, 2013 19:08 |  #3
Channel One wrote in post #15685077 (external link)
Wayne
No not the case.
Channel ­ One
Joined Nov 2010
Mar 07, 2013 05:46 |  #4
extrememc wrote in post #15685318 (external link)
No not the case.
Then that lav was way too far away from the speakers mouth or oriented imporperly .
Wayne
GoWolfpack
Mar 07, 2013 06:36 |  #5
One microphone per person, keeping it a consistent distance away from their mouth at all times. If you didn't capture enough level live, there's not much you can do to restore it later without adding a lot of noise too.
If you can list all your gear in your sig line, you don't have enough stuff.
J_O_S_H_U_A
Joined Jul 2011
Mar 08, 2013 08:22 |  #6
Were you monitoring the audio while recording and were the levels matched then?
Did you use the AGC disable function? The juiced link device you have eliminates the right channel when the AGC disable is switched to on.
www.instagram.com/_j_o​_s_h_u_a_ (external link) www.atomiccanary.com (external link) http://joshuaorozco.co​m (external link)
1,181 views & 0 likes for this thread, 4 members have posted to it.
Needing Audio Help
1842 guests, 139 members online
