Hi all
is it the FF bodies
or the crop ?
and which one ?
i need a clear details in the photos
moltengold Goldmember 4,296 posts Likes: 10 Joined Jul 2011 More info | Mar 07, 2013 05:21 | #1 Hi all | Canon EOS | and some canon lenses
Madweasel Cream of the Crop 6,224 posts Likes: 61 Joined Jun 2006 Location: Fareham, UK More info | Mar 07, 2013 11:03 | #2 The MP-E65 is seriously sharp and will work fine on any body. I would choose according to the likely size of your subject - since the lens cannot come back further than 1:1, it gives a bigger coverage on FF than it does on crop. In other words you can't fit something bigger than 22mm across the crop frame, but you can go up to 36mm subjects using a FF camera. Conversely if you want maximum magnification then the crop gives you the same framing advantage it does with long telephoto lenses. Mark.
Mar 07, 2013 11:11 | #3 Thanks a lot Mark | Canon EOS | and some canon lenses
Also; with equal framing, I believe you will get a larger DOF on say; a 7D than on a 6D. Can make it easier to get more of the subject in focus. [6D]
shadowcat Senior Member 855 posts Joined Apr 2005 Location: Elyria,Ohio More info | Mar 07, 2013 16:25 | #5 I would say the 7D it gives you more magnification and gives you a better chance of catching a bug flying or licking something due to the fast FPS. Canon 5D MK2 with grip,7D w/grip,G1x,300mm 2.8is, 35 1.4L, 24-70 2.8II, 85 1.8, 70-200L 2.8 is, 100L macro, 2x& 1.4 tele, canon pro9000 printer, 600ex-rt,580ex 2 flash, macro flash
Mar 07, 2013 16:35 | #6 thanks w0m and shadowcat | Canon EOS | and some canon lenses
Needsnow Goldmember 1,814 posts Likes: 2 Joined Jan 2007 Location: Nebraska More info | Mar 07, 2013 17:16 | #7 I have used the 7D, T3i and the T4i takes the prize! It allows the lens to be positioned in any way, and I can work with the camera totally from the rotating touch screen......here is a recent winter example... Image hosted by forum (639930) © Needsnow [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Canon EOS R
MikeK Goldmember 1,637 posts Joined Apr 2001 Location: San Francisco area More info | Mar 07, 2013 17:24 | #8 The MPE 65 is a real challenge to use. The dof is really thin, so you may want a focusing rail to move the camera forward/backwards a fraction of a mm. I hope you were counting on using a tripod. You certainly will need a body with a good (~1M dots) Live View, fortunately thats just about any Canon Body in the last 4 years. Some of the LV screens are fractionally larger than others. Crop will allow a greater distance from the subject, which is often an issue with getting enough light onto the subject with a really near filed macro. Conversely FF will have less noise, all things equal. Canon 6D, 1DmkII, IR modified 5DII with lots of Canon L, TSE and Zeiss ZE lenses
Madweasel Cream of the Crop 6,224 posts Likes: 61 Joined Jun 2006 Location: Fareham, UK More info | Mar 07, 2013 17:25 | #9 That's a great snowflake shot. I use an angle finder if I need to, but I guess the swivel screen is even more convenient, using liveview. Mark.
Needsnow Goldmember 1,814 posts Likes: 2 Joined Jan 2007 Location: Nebraska More info | Mar 07, 2013 17:27 | #10 Swivel screen, with liveview and TOUCH is sweet! Canon EOS R
botw Goldmember 1,157 posts Likes: 5 Joined Feb 2009 Location: Potomac, MD More info | Mar 07, 2013 19:10 | #11 I like it on my M, but the t4i would probably be my choice if I have one. Otherwise, something with a large bright viewfinder because it can get very dark at high mag.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Mar 07, 2013 19:19 | #12 shadowcat wrote in post #15688923 I would say the 7D it gives you more magnification and gives you a better chance of catching a bug flying or licking something due to the fast FPS. In truth, if a lens gives 1:1 magnification, it does so irregardless of format size!
But of course, if using a macro lens that can achieve only 1:1, you would have to mount it on an extension tube in order to achieve 1.6x with that lens. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
gjl711 Wait.. you can't unkill your own kill. 57,733 posts Likes: 4065 Joined Aug 2006 Location: Deep in the heart of Texas More info | Mar 07, 2013 19:21 | #13 w0m wrote in post #15688821 Also; with equal framing, I believe you will get a larger DOF on say; a 7D than on a 6D. Can make it easier to get more of the subject in focus. Hmm.. This is worth an experiment. I believe that the FF would actually give you more DOF if using the whole frame but if you try and frame them the same then maybe not. This is worth an experiment. shadowcat wrote in post #15688923 I would say the 7D it gives you more magnification and gives you a better chance of catching a bug flying or licking something due to the fast FPS. There is no way that you are going to be able to get bug in flight with this lens. Even at 1:1 the working distance is quite small and the DOF is really really small.at 5:1 the working distance is maybe an inch or so. You might get really lucky, but I'm not seeing it happen. Not sure why, but call me JJ.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Mar 07, 2013 19:30 | #14 gjl711 wrote in post #15689498 Hmm.. This is worth an experiment. I believe that the FF would actually give you more DOF if using the whole frame but if you try and frame them the same then maybe not. This is worth an experiment. gjl711, if you refer to my immediately prior post, if using a lens on both APS-C and FF and 'filling the frame' (what I assume was meant by 'equal framing'), the FF image needs to capture the object at higher magnification in order to fill its larger frame, so as captured there is LESS DOF from the larger image. But if we then produce an 8x12" print from both images, when have to enlarge the APS-C image by 1.6x greater magnification, thereby the end result (the print) has identical DOF...one was enlarged 1.6x during shooting, the other was enlarged 1.6x during printing, yielding identical results! You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
amfoto1 Cream of the Crop 10,331 posts Likes: 146 Joined Aug 2007 Location: San Jose, California More info | Mar 07, 2013 19:31 | #15 I don't have the T4i, so this may be a dumb question... Alan Myers
| Latest registered member is semonsters 1468 guests, 130 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
