Thread started 08 Mar 2013 (Friday) 12:46
Strange but maybe normal
jaomul
Joined Apr 2011
Mar 08, 2013 12:46 |  #1
I picked up my 7d earlier and without turning it on looked through a very dark viewfinder. I thought it had a problem,but the battery was dead so I could not turn it on. Fast fwd to charged battery and when I turned it on it was fine. I turned it off again and looked through a very bright viewfinder as normal. Being curious I removed the battery and it went dark again. I had a tamron 17-50 attached. It seems (and I could be way off here) that the lens closes down when no battery is installed. Is this correct. I also noticed the battery often goes dead pretty fast when the camera is off. Could this be linked?? Thanks for any input
Olympus EM5,Nikon d7200,
Olympus 12-50mm, 40-150mm,17mm f2.8,Nikon 50mm F1.8, Tamron 90mm vc, 18-105mmVR, Sigma 18-35 f1.8
jhjl1
Joined Sep 2003
Mar 08, 2013 14:06 |  #2
I am not sure about the lens closing down or not. You could charge your battery and take the lens off and see if it stilll drains the battery at the same rate.
James
Canon T3i, Canon G15, Canon 50/F1.4, Canon 100/F2.8 Macro, Canon 17-40/F4L, Canon 70-200/F4L, Canon Extender EF 1.4x, 2-Canon 420EX's, 1-Canon 320EX, 1-Canon 270EXii, Manfrotto Tripod, Monopod, Ballheads, Light Stands, Do-Dads and misc. items galore.
http://www.flickr.com/​photos/myeyesview2/ (external link)
patrick023
Mar 08, 2013 14:17 |  #3
The viewfinder has a transmissive LCD, so it needs power otherwise it appears dark. As far as the battery drain issues goes, it could be a bad battery or if you're using a grip, try it without the grip.
PacAce
Joined Feb 2003
Mar 08, 2013 14:18 |  #4
jaomul wrote in post #15692190 (external link)
No, it's not your lens stopping down. The lens doesn't do that until you actually take a picture with the aperture set to other than max aperture. It's actually the viewfinder screen itself that's going dark when you pull the battery out.
...Leo
amfoto1
Mar 08, 2013 14:35 |  #5
patrick023 wrote in post #15692520 (external link)
This is correct. It's the transmissive LCD. The viewfinder will dim down when the battery is removed or completely dead. When a charged battery is reinstalled, even with the camera turned off, as soon as you close the battery door the viewfinder will brighten about a stop (Note: There's a microswitch on the battery door, there's also one on the memory card door, but opening it doesn't turn off the LCD. Only the switch in the battery door turns off the LCD). The indications on the focus screen LCD (i.e., the grid, if using it, and the AF point boxes) are only active when the camera is on and awake.
Yes, there's always a small amount of drain on the batteries, keeping the LCD on. It's not much drain, though. I've had a 7D sit unused for over a month and only then did the two Canon LP-E6s need to be charged (camera is gripped and there are two batteries, so if not using a grip it might need a charge sooner). There was still enough power remaining to take some shots. I wouldn't call it fast, by any means.
I also agree. It has nothing to do with the lens. It's not stopping down. The same thing will occur whether a lens is on the camera or not.
If your batteries are draining rapidly, either they are getting old and need replacement, or your charger isn't up to snuff for some reason, or the camera itself is using more power than usual while in sleep mode for some reason. I only use Canon OEM grips and batteries, don't know about third party batteries and grips. There may be some issues with some of them, too. I know some 3rd party LP-E6 clones don't report/register correctly to the camera. I'd be concerned about those. They mustn't have the circuitry of the OEM or maybe are programmed incorrectly.
I also can't say what the lifespan of a 3rd party battery might be. I've been using a dozen LP-E6s in my two 7Ds and 5DII for over three years, some close to four years, and have taken approx. 200,000 shots with them, between the three cameras. The batteries still charge just fine and I get upwards of 1200 shots per battery per charge (in the 7Ds). I'm also using OEM Canon chargers.
It doesn't really matter if you turn the camera off at the switch, so long as the camera is set to go into sleep mode fairly quickly. I very rarely remember to turn my 7Ds off. Sometimes I do specifically to run the cleaning cycle. But more often than not I put them away with the switch on, since it doesn't seem to matter... sleep mode conserves battery charge just as effectively.
Since 7Ds wake up almost instantly at the touch of any of the buttons, I have mine set to sleep in the shortest possible time (2 minutes?).
jaomul
Joined Apr 2011
Mar 08, 2013 17:59 |  #6
Thanks all for the info. You learn something new everyday
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Mar 08, 2013 19:59 |  #7
page 26 in the English manual.... ;) It is amazing how much you learn about the 7D by reading the manual, even after you had one for a long period of time and thought you knew all there was to the camera. :)
jaomul
Joined Apr 2011
Mar 09, 2013 00:58 |  #8
TeamSpeed wrote in post #15693574 (external link)
Ouch!!- fair enough, I missed this
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Mar 09, 2013 05:15 |  #9
It wasn't meant as a dig, I personally will look through the manual a few months later, and it is amazing what I find that I had missed the first time thru.
jaomul
Joined Apr 2011
Mar 09, 2013 05:36 |  #10
TeamSpeed wrote in post #15694482 (external link)
No bother, I didn't really think it was, and even if it was I am not so sensitive. I get plenty of good 7d info from your posts and all info appreciated. Thanks
1,977 views & 0 likes for this thread, 6 members have posted to it.
911 guests, 118 members online
